Steering wheel replacement
Car: 88' Firebird
Engine: 2.8L
What kind of work am I looking at if I want to change my 88 wheel with one from a late 90's model. (I am not worried about the airbag and there are no electronics on the current wheel)
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Take you about 30 minutes.
Just need a large socket and ratchet, steering wheel puller, and small torx bits for the 90+ with the airbag.
I just did this swap last weekend.
Really easy to do! I don't even think it took 30 minutes.
You'll need a steering wheel puller, they have them at shucks for under $10
The newer wheel looks so much better.
Here was the old wheel.
Here is the wheel out of a 92.
Chris.
Chris.
Car: 1989 Firebird
Axle/Gears: ?
dont mean to hijack the thread, but on relation to steering wheels and colums for our thirdgens, can a steering colum out of a camaro be used in a firebird/ta?
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
also the internals and upper case part are the same as alot of other GM cars... basicly if the collar of the car looks like ours, for the most part the guts are the same.
Car: 82 camaro SC
Chris.
Chris.
Yes the steering wheel is easy to install. Mine took some effort with the puller--after that it was simple. I got the grant wheel new on ebay for 40 bucks.
Car: 1989 Firebird
Axle/Gears: ?
Originally posted by MrDude_1
they're the same.
they're the same.
Car: 91 Camaro Vert
Excellent, cause im my ta now i have a non-tilit column, and i can get a tilt column for next to nothing. thanks
before you unbolt the tilt column from the other car, press down on the wheel and see if it rocks a little..
if it does, you might want to take it apart on the work bench and tighten it up.. its a lil easier then in the car i think... if it does move, its usually just the screws holding the tilt... they tend to loosen over time....
Car: 1990 TA
Engine: LB9 305
Transmission: 4L60
The newer wheel looks so much better.[/B]
I've been going nuts the past few months trying to score the older style Firebird steering wheel for my '90. Finally won it yesturday. Can't wait, I'll have a nicer looking wheel and I'll be able to see the gages.
backtothe80s
Sep 5, 2015 12:39 AM
