140 speedo can i get faster
Car: 1994 firebird
Engine: 427ci lsx bowtie block
Transmission: tremec t56 micro edged gears
Axle/Gears: Strange dana 60 with racing spool
i have an 87 GTA with a 140 mph electronic gauge cluster. i want to get a speedo that goes up to 200 or more 300 would be great. i dont care if it is stock looking or fitting into the old speedo spot i just dont know where to get anything like this. i iwll make it fit in my car if i can but i need something to work with. someone let me know
Car: 2013 Challenger RT
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
280
You could easily change the existing speedo to a higher mph by using an ERA from www.atrol.com I bought one for my 87 TransAm because I changed the gears in the rear end from a 2.73 to a 3.73. But you could buy one of these and change the pulse ratio to the speedo so that the speedo will read slow, then you can renumber the speedo with decals yourself, or send it to a guage rstoration/speedo shop (find them on lycos) and they will do it for you.
Car: 1987 Chevrolet Camaro Z28 IROCZ
Engine: L98 350, mini ramed and camed
Transmission: T56 6 speed manual
Axle/Gears: 10 bolt 3:73 limited slip
try autometer, I think they have some 200 mph ones.
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
Car: 1994 firebird
300mph speedo
i know they make a 300 mph electronic speedo for camaro's and monte carlos but not for trans am's i dont think. i see it in my hot rodders mag. it would be cool if i could get a stock looking one. i will check out your sugestions and let you guys know. also does anyone have any interest in a tremec 6 speed i have for sale have flywheel back. works great. was looking for 1500 not including shipping only 30 k miles on it
Car: 1994 firebird
140 mph speedo
hahah i am not running on salt flats i dont need a 300 mph speedo but i want one that does atleast 255 since that is when my fuel pump will shut off. some day i will get my car that fast with the right engine and low rear end gears. i am sure i can do it but i want a speedo that can handle it also. i iwll be like red lineing the car at 10000 rpms or something i am sure when i do it but i am going to a build an engine that can handle it. so anyone let me know what you come up with and also emial me at polygaryd@yahoo.com if you want that 6 speed. it is clean and in great working order i will money back gaurentee it
Car: 88 camaro
Transmission: 5 spd
Axle/Gears: 10 bolt, 2.23
Re: 140 mph speedo
and i know this thread is probly dead but i was just browsing and i found it
Car: 1983 T/A
Engine: OUT (350 Block)
Transmission: 700-R4 sometimes
Axle/Gears: 3.23, moser 12 bolt >=3.73 someday
From Jegs.com
Ultra-Lite 5" electrical gauge
Speedometer, 200-MPH, In-Dash Mount
105-4490
Ultra-Lite 3 3/8" electrical gauge
105-4486
This programmable speedos feature ''push-button calibration'' that can be easily set while driving. This makes changing gear ratio or tire size easier than ever. The LCD odometer is highly visible and retains the actual mileage after recalibration or in the event 12-volt power is removed, also includes a resettable trip odometer. Will work with late-model transmissions that have an electronic (500 to 400,000 pulse/mile sender) output. Requires sender 105-5291 or 105-5292, if using an early model (cable driven speedo style) transmission.
105-4490
105-4486
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
Originally posted by NEEDforSPEED
i want one that does atleast 255 since that is when my fuel pump will shut off....
lmao, are you seriously
Car: 1994 firebird
Re: 140 speedo can i get faster
exactly! prom cuts off fuel at 255 has nothing to do with how much fuel it flows. and hey it may be an unattainable goal but at least i have one.. what r u doing with your time besides trying to type correct english grammer "are you seriously". haha also i am not sure if if any dynos will go that fast but you may not need roads to test the top speed and have it be that fast. the rest of you thanx for the tips on speedos and where to buy them.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
I can't get over the 664 days between the last couple posts!!! And responding as if only a second went by.
Amazing how time flies.
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
if you go 255 you are going to have a camaro that does cart wheels....lol there was a EXTREAMLY rare 160MPH dual pointer that was in 82 cross fire indy 500 pace cars and not all of them had it take a look........... but that original idea of re calbing your speedo and getting a new face plate will work good
Car: 1994 firebird
cart wheels i think not.. and no you dont need a wind tunnel, like i said a dyno can do it in place i am sure.. anyway i have found some digital ones that go to 300 mph for the camaro and none for trans am but i still havent found any electric ones that go above 200 mph.. also it was a long time before i responded but that is because i came across this post while searching for another one i had listed for parts for sale and thought that one of the users is a complete tool to everyone and he should shut his mouth unless he is being helpful which he hasnt responded here so maybe he got the hint.
Car: 87 Trans am
Engine: 350tpi
Transmission: 6spd
Axle/Gears: 4.10
I think he means to find out the top speed the car can reach on the road you would need a windtunnel because there would be no wind resistance on a car on a dyno so you may be geared to go that fast but never really be able to hit it on the road.
Car: 92 camaro rs
why would you program the fuel cut at 255 does the car really go that fast and if so why limit it to 255 if it has the power and ability to go that fast why not just disable the fuel cut also what ecm are you using that has fuel cutoff in it
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
You can get a dakota digital dash or one from Cyberdyne tech. I understand about the fuel being cut off at 255. I don't know how you are planning on over-riding that in the ECM though. You will have other issues long before you ever think about getting a Camaro to over 200 mph though.
You could get a Dakota Digital or Cyberdyne digital dash. You might not ever see over the 200mph though.
Car: 1994 firebird
Re: 140 speedo can I get faster
Car: 1994 firebird
oh btw I came across this wicked old thread searching for another one of mine in the classifieds so I thought I'd post to it.
Car: 1987 IROC-Z
I still have my Series 2 Dakota Digital Dash for sale for $200 if anyone is still interested.. I took it out about 3 months ago to install the newest Dakota Dash after I returned back from Afghanistan.
This digital dash works 100% and goes to 255 mph.. I have enclosed another picture of what it look like when installed into the car. It will be shipped in a protective pelican case because of the electronics.
You can contact me directly me directly @
ibmtech@twcny.rr.com
Hotrodboba400
Dec 10, 2019 07:07 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
, are you runnin this thing on the salt flats or what (seriously)?
