how do u get the head light switch off?
Old Oct 13, 2003 | 07:04 AM
aziroc's Avatar
Car: 86 IROC-Z
Engine: 406
ok..well. subject says it all. how to u get that stupid black thing off the metal pole??
Old Oct 13, 2003 | 08:16 AM
mr. listo's Avatar
Car: 1989 iroc-z
Engine: 350-5.7ltr
Transmission: 700r4 automatic
OK. IF THE SWITCH IS STILL WHERE IT SUPPOSE TO BE. YOU HAVE TO DISCONECT THE BATTERY, BECAUSE YOUR LIGHTS WILL STAY ON WHEN YOU PULL THE BLACK **** WITH THE METAL PIECE. 1 YOU PULL AS IF TO TURN ON YOUR LIGHTS 2 TWIST LIGHTLY LEFT THEN RIGHT AND PULL TOWARDS YOU. YOU DO THIS RIGHT IT IS SIMPLE BUT YOU HAVE TO BE PATIENT.
IF YOU HAVE THE **** OUT OF ITS ORIGINAL SPOT. LOOK BEHIND THEBLACK KNON WHERE THE METAL MEETS THE PLASTIC THERE IS A SMALL LOCK TYPE THING POKE IT WITH ANYTHING SMALL ENOUGH TO GET IN THERE.THAT SHOULD RELEASE THE ****. I HOPE IT HELPS
THE HAYNES REPAIR MANUAL WOULD HELP YOU TREMENDOUSLY
ABOUT $12.00 @AUTOZONE:hail:
Old Oct 13, 2003 | 08:33 AM
Blackroc86's Avatar
Car: 1986 Iroc
Engine: 454 Demon 850DP
Transmission: TH350, 3500 stall
Maybe lose the caps.
BRoss99
Aug 10, 2025 05:08 PM
The_Phoenix
Feb 4, 2016 07:10 AM
tnrednneck
Aug 13, 2015 08:57 AM
mustangman65_79
Aug 12, 2015 06:39 AM
Omega
Aug 10, 2015 12:46 PM
