are the door panel ground effects bolted on?
Old Oct 14, 2003 | 01:44 AM
MiscCamaro's Avatar
r they bolted or just stuck on there with some kind of adhesive on the door panels?
Old Oct 14, 2003 | 02:00 AM
ERICK87Z28's Avatar
Car: 1988 IROC
Engine: 5.7 HO TPI
Transmission: 4 spd Auto
Bolted....there are nuts on the inside of the door. If you were to take off the door panels, you would see them way down low. Like the rounded acorn style nuts.
Old Oct 14, 2003 | 08:56 AM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
okay if youre trying to take them off....theres screws in the door jam on the floor, i believe theres screws on the bottom of the gfx underneath the car, theres a screw underneath the graficks near the front you have to pry that off, and to get the screw off the back you have to go from the inside of the sail panel, take off the little cover, pull the speaker and theres a nut down there.
Old Oct 14, 2003 | 11:24 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Two exterior acorn nuts, one at the front of the door, one at the back and three regular nuts inside the door, 10mm if I remember correctly.
JamesC
Frozer!!!
Jan 19, 2024 04:55 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Out-Cast
Aug 23, 2015 06:33 AM
92firebirdchris
Exterior Parts for Sale
Aug 14, 2015 11:56 AM
