Leaking Rear Hatch
Old Oct 19, 2003 | 09:47 PM
TransAmman87's Avatar
Car: 90 Trans Am
Leaking Rear Hatch
My Trans Am's rear hatch is leaking everytime it rains. The bottom of the trunk fills with water and the drivers side wheel well fills with water also. I thought the weatherstripping was bad so I replaced it. It rained and the water was laying in the backend again. I have no idea what to do. I searched for anyplace water can get into and have found nothing. My spoiler is shot, but I don't think water could be getting down inside the cracks, or could that be it? Please help if possible.
Old Oct 19, 2003 | 09:56 PM
bonz's Avatar
Car: 89 GTA
I had a problem with my trunk leaking on my 87 firebird. I noticed that the spoiler and the part it mounts to was 1/4 to 1/2 inch farther back than it should have been. I could see that the last people who owned it did a bad job putting it on. So i took it to a body shop and had them re-seal it and move it back to where it should be. And no more leaks. My t-bar was also leaking along the grove of the hatch. Water leaking in from the inside really rust out a car.
camarogirl18's Avatar
Car: 1991 Chevy Camaro RS
Engine: 283
Transmission: 700r4 Auto
i have about the same problem except the wheel wells dont leak...i have no idea how the water is getting down in my trunk...weatherstripping is good,only other thing i thought maybe it could be was the glass needs resealed,i dont know though
Old Oct 20, 2003 | 12:38 AM
89V6FBIRD's Avatar
Car: 1999 Pontiac Trans Am
Engine: LS1 - 346 ci
Next time do a search...
https://www.thirdgen.org/techbb2/sho...ght=hatch+leak
Old Oct 20, 2003 | 12:45 AM
89V6FBIRD's Avatar
Here's where it's leaking.
Old Oct 20, 2003 | 10:03 AM
Car: 90 Trans Am
I have already read the link you have posted 89V6FBIRD. The problem is that it didn't help. Plus you showed that pic of the glass meeting the hatch deck. I already put silicon down in there. That didn't help. Any other suggestions.
Old Oct 20, 2003 | 10:21 AM
SHAGME's Avatar
Car: 1988 IROC-Z
Engine: 355ci TPI WORKED TO THE BALLS!
Transmission: 700R4 T-56 coming
I had the same thing in that spot. I used clear silicone and no more problem.
Old Oct 20, 2003 | 10:43 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
This is a crappy way, but remove as much trim as you can, then youself and assistant take to car wash. you sit inside and look while other sprays.
I did this on my cavalier hatchback(first car) and found it was where the glass meets the deck shown in that picture.
Old Oct 20, 2003 | 01:22 PM
Adam Jones's Avatar
That's actually really smart
Old Oct 20, 2003 | 01:39 PM
SHAGME's Avatar
Car: 1988 IROC-Z
hey its been good for 9mos and counting and yes the car sits outside and u cant see it
Old Oct 20, 2003 | 08:16 PM
Engine: 283
didnt help me any
Old Oct 20, 2003 | 08:17 PM
Engine: 283
where do you get the clear silicone? autozone? is that the name of it "clear silicone"?
Old Oct 20, 2003 | 08:58 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
Yep its called clear silicone.
Old Oct 20, 2003 | 09:18 PM
Motor City Mike's Avatar
Car: '82 Trans Am
Engine: Blown 540 BBC
Transmission: TH475
Axle/Gears: Dana 60, 4.10 w/spool
I actually prefer to use a strip of butyl tape in this situation. If you ever need to remove the rear panel from the glass (to reseal it, or re-align it), you'll play hell trying to get it off or move it, if you use silicone sealer.
Just my $0.02
Old Oct 21, 2003 | 01:55 AM
Engine: 283
Just my $0.02
how does the tape work???
Old Oct 21, 2003 | 08:25 AM
Car: '82 Trans Am
Transmission: TH475
Well, it's actually a very sticky, pliable 3/8" diameter material that comes coiled like a rope. It's what they use to install windshields on cars (without air bags). It's available at most auto parts stores. The rear panel needs to be removed from the glass to to replace the existing seal with the butyl tape. It also needs to be stretched out to make it thinner when installing it (about 3/16" or so).
Old Oct 21, 2003 | 06:29 PM
Engine: 283
and the clear silicon you just squirt it in between the hatch deck & the glass?
Vintageracer
Jan 10, 2020 05:33 PM
Street Lethal
Apr 30, 2019 12:14 PM
madsv1000
Aug 20, 2015 06:45 AM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
