Carbon Fiber hoods and 2nd gen spoilers
Old Oct 14, 2003 | 12:28 AM
Black363IROCZ's Avatar
Car: '88 IROCZ
Engine: 363 Vortec w/Miniram
Transmission: built 700r4
two questions here:
1) are there any carbon fiber hoods out for the 82-92 Camaro (with louver provisions) not interested in the carbon fiber pattern (Id paint it black to match the car) more interested in the very light weight of the material over the 50 lb steel hood.
2) would it be possible to mould a 2nd gen spoiler onto the decklid (the 3 piece one) or is it too narrow/long? if it's too long it could be cut, but would it fit. I like the way they look but I'm not too sure how it'd be on a 3rd gen, guessing it'd be like a cheaper version of that 5" spoiler from thirdgenresource.com
Old Oct 14, 2003 | 07:33 AM
anubiscougar's Avatar
i'd like to find a ram air hood, like the ws6 i think it is, can't remember, that's carbon fibre.. but.. the people who make things out of carbon fibre don't really like domestics.. so they don't do anything for us.. we get jipped on that kinda stuff. :-/
I do however remember seeing a carbon fibre hood on a 3rd gen camaro, not sure what year. It was a typical hood tho, nothing special, or flashy, or sexy. Just straight out.. Hood.
Do a search, i'm sure you'll find it.
Old Oct 14, 2003 | 10:25 AM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
From what I understand there is a company that makes a stock "flat" hood out of carbon fiber but I would not buy it. It may be a little lighter than fiber glass but the problems that I have seen with carbon fiber is that it has a tendency to explode if it were hit or damaged and cannot really be fixed, only replaced. Fiberglass can be fixed. It's up to you though. The other thing is that carbon fiber is pretty expensive. That's my thoughts on it.
As far as the spoiler, thirdgenresource is the only place that has it. You may be able to find someone locally that does glass molding, it thier any good, they could probably make one for you. Might want to ask around any speed shops and some of the racers at the track that deal with glass molders.
Good luck on your quest though.
Old Oct 14, 2003 | 11:31 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
https://www.thirdgen.org/techbb2/sho...rbonfiber+hood
just a few of the threads. do a search on carbon fober hoods
Old Oct 21, 2003 | 04:39 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
I'm looking at the possibility of using a 2nd gen trans am spoiler for my 84 and have also looked at the Camaros to see if their 2nd gen spoiler would line up. From what i've learned, the second gen decklids are not as long as those on the 3rd gens. Also, if you look from the side, the 3rd gen camaro taillights have a steeper incline angle than the 2nd gens. There is no bolting on possible. I'm hoping to give it a shot with the firebirds by modifying the original 2nd gen spoiler by any means neccisary and creating a mold from it to produce a fiberglass spoiler that will fit on the 3rd gens. I did 2 photoshops to see how it would look when finished and i'm impressed by it. let me know what you think
Attached Thumbnails Carbon Fiber hoods and 2nd gen spoilers-3pc-attempt-1.jpg
Old Oct 21, 2003 | 04:40 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
I think this one looks really awesome, partially because of the color of the car.
Attached Thumbnails Carbon Fiber hoods and 2nd gen spoilers-3-pc-attempt-3
Old Oct 21, 2003 | 04:53 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
what is that thing in the last pic? i dont care to much for that. i think if it was laid back a bit or sloped more the spoiler would look better but not straight up.
Old Oct 21, 2003 | 05:21 PM
gearhead0384's Avatar
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
I agree with spartyon, it does have the right flow to it.
Kevin
Old Oct 21, 2003 | 08:56 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
i was going to mention this when posting it... it does look high in the second pic and i'm not sure if it's due to distortion of the image or if that's how it would really look. Photoshops aren't perfect. However, in the first pic, it ended up being a little lower than the ramairhoods.com 4th gen style spoiler was. I'll have to take some measurements of the real thing and do a reality check.
Old Oct 21, 2003 | 09:37 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
one thing ive learned recently...
99% of all mass produced carbon fiber hoods weigh the same as the same thing in fiberglass.
just FYI
Frozer!!!
Jan 19, 2024 04:55 PM
tricky1
Aug 23, 2015 01:17 PM
AkDrifted
Aug 17, 2015 07:45 PM
Randomtask2
Aug 13, 2015 01:57 AM
