tilt wheel
Old Nov 1, 2003 | 01:41 PM
bob8748's Avatar
tilt wheel
Was wondering if any of our cars came with a tilt steering column. Sorry if this is a stupid question but I only know of my 87 and with dash clearence I dont see how. Column needs replaced and a tilt will make climbing in and out of cage a lot easier, but if I read the NHRA rules right it must maintain a stock length steering column. Dash pad wont matter, That will be modified as well.
Old Nov 1, 2003 | 02:11 PM
85TransAm406's Avatar
Car: 1985 Trans Am
i've owned 4 thirdgens and all of them had tilt columns.
Old Nov 1, 2003 | 02:24 PM
bob8748's Avatar
Thanks 85, no where needing it yet but thinking ahead. How 's the car handle with that 406?
Old Nov 1, 2003 | 02:42 PM
Car: 1985 Trans Am
My hydraulic cam is kinda small, so i sometimes forget about the extra 101 cubic inches i put in it, until i give it a little extra gas through a turn with my stock 15x8 inch wheels and 235/60R15s on the back. Then i'm staring in the direction i just came from (happened twice, but on back roads back home in AL. don't drive like that in town).
Old Nov 1, 2003 | 05:22 PM
cc 82Z-28's Avatar
Car: 82 Z-28
Engine: Built 406ci
Transmission: 700R4 w/3000 stall
Axle/Gears: 3.73 Torsen Posi, Moser Axles
Also, do yourself a favor and locate one out of a donor car of the same year if possible since that will make it a direct bolt in and plug in for the wire harnesses that hook it up to the electrical and ignition. My 82 didn't have a tilt wheel and yes it's a pain to get in and out of the car, especially as you get older as I am. Take your time and do get the coupler good and tight should you tackle this project, otherwise your steering will feel sloppy.
cc 82Z-28
Chiknhawk
Wheels and Tires
Jan 29, 2017 10:19 PM
JB82Z-28
Exterior Parts Wanted
Oct 6, 2015 09:05 AM
Fionnla
Wheels and Tires
Sep 11, 2015 11:07 PM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
