GFX screws, nuts and bolts
Old Nov 5, 2003 | 11:16 PM
Diabolical's Avatar
Car: 85 Trans Am WS6
Engine: 305HO L69
for the majority of the summer, my car was sitting in the driveway with no motor, no interior, and no gfx. i had the nuts and bolts in separate coffee cans. we just finished rebuilding the motor and dropped it in this weekend, now we're going crazy looking for all the bolts and crap to hook everything up to the motor. i think we have everything, but in the midst of all the searching, a lot of the coffee cans were combined into one. now i' having trouble figure out which screws, nuts and bolts were for the gfx. what kind/size screws are used for gfx? how many should i have?
Old Nov 5, 2003 | 11:23 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
if no one replies before tommorow night ill go and count and tell you exactly where and how many there are.
Old Nov 6, 2003 | 08:02 AM
bubbareno's Avatar
Car: black on red 92 rs
Transmission: t-5
If your talking about the ones on the side theres 3
Old Nov 6, 2003 | 08:06 AM
bubbareno's Avatar
Transmission: t-5
If your talking about the one up front there like 20
Old Nov 6, 2003 | 08:04 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
most of the gfx bolts are speed nuts. funny looking nut with one thread at the top.
Old Nov 9, 2003 | 09:18 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
on my 85 z the rear gfx has a 10 mm nut with w loose washer on it it is the same style that holds the front nose on. the rest on the door ect are speed nuts cheap tin nuts that are used on unthreaded plastic. the bottom gfx have small screws with hex heads like a 7 mm socket i belive. and under the doors are screws self tappers. hope this helps.
Jeff
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
New2Chevy
Sep 28, 2015 12:35 AM
billybob6110
Sep 23, 2015 01:30 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
