Halogen lights
Old Nov 15, 2003 | 07:38 PM
92birdie's Avatar
Car: 1992 Pontiac Firebird
Engine: 3.1 V6
Transmission: 5 Spd. Manual
Halogen lights
Not sure if this is the right place for this so forgive me if im wrong,
Hey guys,
Just wondering if anyone has put halogen or what ever the blueish tint lights on there thirdgen?
If so do you have the partnumber?
there going on a 92 firebird
im thinking the fog lights only but im not sure, Depends if they look dorkey or not.
thanks
Craig
Old Nov 15, 2003 | 08:29 PM
twiztid dreams's Avatar
Car: 84 Firebird
Engine: 2.8l
ur looking for some HID lights. couldent tell ya bout them being install'd on a 3rd gen tho sorry man.
Old Nov 15, 2003 | 09:21 PM
92birdie's Avatar
Engine: 3.1 V6
thanks, like I said im not sure how there going to look I dont want it to look like a import u know.
thanks again
Craig
Old Nov 17, 2003 | 08:09 AM
rallysportridin's Avatar
Car: 1989 Camaro RS
Engine: 305 tbi
Transmission: 5 Speed
two ways that i know
There are two products that sylvania makes. One is an actual HID conversion will all the parts that gives you that expensive BMW or lexus blueish purpelish tint, but this kit which is the Xenarc x4656 is most of the time hard to find and expensive, i have seen them from $350 to $500 this website has them
http://www.buytruckstuff.com/product...y=26&p_gpID=99
Then the other product by slyvania is the silverstar wich is a replacement halogen that is at a 4000k temp., which will give you a clean pure white look, instead of the yellowish offwhite look from halogen. This headlight H4656 ST , will put you back about $30 to $50 from what i have seen. This website has them
http://www.global4autoparts.com/Prod...Star_Bulbs.htm
I have looked into this for a while, i hope it helps some!
Old Nov 17, 2003 | 07:32 PM
92birdie's Avatar
Engine: 3.1 V6
yea, thanks alot Im still not sure if halogen is the look im looking for.
I can just picture it looking like a cheap import.
thanks for the info though
Craig
Old Nov 17, 2003 | 10:21 PM
BruceEmbry's Avatar
Car: 82 Ponitac Firebird
Transmission: 4L60e/TCI TCU
Hi,
I have converted the Headlights on my 1982 to Bright White H4 using APC Coomposite Headlamp, Bright White H4 bulbs, and wiring harness.
The wiring harness provides power directly from the battery though relays that are control by the orginal light circuits.
The complete conversion set me back about $125. I purchase all of the parts at my local Advance Auto Parts store.
The Headlight lens part number is 403654HL
I had to modified the Headlamp mounting bracket to make the lens fit. One nice feature of the Headlamp lens is that it comes with a rubber gasket that makes a good moisture seal for the H4 bulb. The wattage on the bulbs are 55/60 watts. They provide a vary biight white light.
Old Nov 18, 2003 | 02:13 PM
92birdie's Avatar
Engine: 3.1 V6
thanks again for the help and product #'s
did u see any dffernce between the two types?
Old Nov 18, 2003 | 07:23 PM
cdoyle's Avatar
I also converted to the H4 bulb, I got my kit from eurolights.com. At first I wasn't happy with the company because they didn't tell me I would have to rewire to use these bulbs, but the job wasn't too hard, and there is a tech article on this site on how to do it. So if you have a day to do the job, I say go ahead and go with something like this.
The bulbs I got are 85/100W Xenon filled, and have a color rating of 4800k
They look pretty good, and are way brighte then the silverstars I had before.
Chris.
Old Nov 19, 2003 | 06:02 PM
BruceEmbry's Avatar
Chris.
Hi Chris,
I doubt that you ever get busted, but the 85/100 watt bulbs are only for off-road use.
Old Nov 19, 2003 | 06:40 PM
cdoyle's Avatar
Ya I doubt I'll get busted for them either, I've had them on for almost a month now, and I haven't had 1 person high beam me or anything.
When your looking right at them, they really don't blind you at all, but they really do light up the road better.
I must just have them aimed right or something, so many people out there have them pointed to the sky, its no wonder they get pulled over.
Old Nov 20, 2003 | 01:50 PM
ThirdGenFire's Avatar
Car: 2000 Trans Am and a 85 Iroc-Z
Engine: The Mighty LS1& 305 just beat meTPI
Transmission: 4L60E and 700R4
Yeah the SilverStars look good on my IROC. I work for CSK(Checker,Shucks & Kragen) and we sell the SilverStars for $19.99 right now and the converstion kit for $800(if I remember correctly). The Stars look great man.
Old Nov 20, 2003 | 02:00 PM
Tremo's Avatar
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
Yeppers. I have Silverstars on my IROC as well. They work great. I think I paid like $20 to $25 per bulb.
The only disadvantage of the Silverstars, and any other of the bluish bulbs, is when it wet and rainy or foggy. The fog or moisture in the air, and wet road surface reflects the blue back at you MUCH worse than stock halogens, making it sometimes hard to see. To solve this, I put the gold ion dichroic bulbs (slightly golden yellow) in my fog lamps, and they cut through the moisture like a hot knofe through buttah. If you want to go with lamps with a color temp of 4000K or higher, I would strongly recommend upgrading your fogs with gold bulbs. It's nice to be able to see when it's raining.
Putting blue bulbs in your fogs would make them essentially useless.
Old Feb 8, 2004 | 09:04 PM
ScrapMaker's Avatar
Car: 2000 Trans Am WS6 (Black)
aren't there sealed-beam silverstar bulbs... how do those compare to the silverstar h4 bulbs?
Old Feb 8, 2004 | 10:34 PM
Red87SC's Avatar
Car: 87 Trans am
Transmission: built 700R4
Axle/Gears: BW 9 bolt posi w/ disc
i have the silvania 4656CB in my camaro, they look very nice. they arent blue, but they are a very solid white and look very good. think about those. anything that will work from silvia is a 4656, the only difference is the letters after the 4656
Old Feb 9, 2004 | 08:49 PM
ScrapMaker's Avatar
hey tremo, what wattage are your gold dichroic bulbs that you put in your fog lamps? I can only seem to find 70watt and 100watt versions... and won't that melt something? I put in some 100watt sylvannia(cheap ones) and they started melting the plastic in about 10 minutes...
TrevinE
Sep 14, 2015 03:20 PM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
luvofjah
Sep 3, 2015 07:08 PM
