Hood/ Facia fit?
Old Nov 15, 2003 | 10:31 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
Hood/ Facia fit?
During the restoration and repair of my 1986 IROCZ I had to remove the front facia (bumper cover) to replace the long plactic thing that holds the headlights and upper portion of the facia in place. I also replaced the hood.
Now I cannot seem to get the gap between the front edge of the hood and the top of the facia reduced to the point where they should look correct. The gap is still way too big. I have seen pictures of many Camaros and some original sales brochures that all show this gap to be nearly "ZERO".
Do I need to remove the whole thing and start over again? I feel like I must have missed a step somewhere during my installation.
Has anybody had and solved this problem?
Thanx, andyZ28
Old Nov 16, 2003 | 08:34 AM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
hows the hood line up at the windshield? may be a hood alignment and not the front end.
Jeff
Old Nov 16, 2003 | 09:09 AM
ANDYZ28's Avatar
Car: 1982 Z-28
It seems to be lined up pretty well at the base of the windshield. It appears to me that the center of the facia needs to come up about 3/4". I have tried forcing the facia into place where it fits better at the top. But then it deformes the facia hear the center.
Old Nov 16, 2003 | 10:31 PM
Thirtybird's Avatar
Car: 91 Z28/99 WS6/02 WS6
Engine: All 350's :)
Transmission: 700R4 & 2 Tremec T56's
did you replace the hood with a Harwood by any chance? Based on what I have seen, that may happen with the Harwoods. Does the hood need to go forward or down to line up properly?
Old Nov 16, 2003 | 10:57 PM
ANDYZ28's Avatar
Car: 1982 Z-28
The hood is a stock GM item. The hood can't go down or forward any more.
Old Nov 17, 2003 | 12:58 AM
JeffW's Avatar
Engine: 305 tpi LB9
i would loosen the front again and put some up pressure on it when you tighten and try that, the middle is mostly supported by the head light bar and the metal brackets after that. i pulled up on my light bar when installing it and it lined up ok, i forget how many bolts on the bar 2 each end maybe.
Jeff
Fronzizzle
Feb 9, 2017 09:31 AM
New2Chevy
Sep 28, 2015 12:35 AM
armybyrd
Carburetors
25
Sep 13, 2015 01:49 PM
BOOT77
Sep 5, 2015 03:55 PM
Formula_88AE
Sep 3, 2015 01:47 PM
