90-92 GFX (not fbrglass) repair?
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
I have a ground effects set from a 90 RS. Most of it is fine except on the front lower part. On the corner it is torn/cracked 80% of the way from top to bottom.
Is this repairable? If it is, how so?
'90 GFX are the same as '85-89. The ones with scoops in them is '91-92.
I recntly had mine completely messed up on an otherwise great looking car. A crack goign through about 90% of it, cept form the bottom up, only held on by a small strip of fiber. I am gonna glue a big paint stick in behidn it to hold it together and temporarily mount it back in place until I get around to doing all my body work, which includes replacing the GFX.
For yours, I would just replace it with one from a junkyard.
Car: 92 Z28
Engine: Boosted LSX
You can get plastic epoxies to fit it. notch a v in the back so you get good adheasion and fill it. sand it flush and make sure you scuff it. They so a fiberglass leyup over the back for extra strength.
