rocker panels what?
Old Nov 30, 2003 | 09:43 PM
sittincamaro's Avatar
Engine: IVTEC 2.4L aka SBC
Transmission: auto
rocker panels what?
i feel real dumb asking this but what hold the rocker panels on my 88 camaro? i have all the screws out but it seems like there are 2 clips ( 2 in front maybe 2 in the back?) that are holding it to the fender and the 1/4 panel. i cant break them A. because that would suck and B i have to save every penny i can. anyone know what i can do?
Old Nov 30, 2003 | 09:53 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
I'm assuming you have a camaro and that rocker panels are the side GFX....in that case there are two things you need to do. First pry off the emblem near the front of it and there are two screws under there. Then to get the back one off take off the sail panel in the back seat where the speakers are (single screw then lift it up and pull out) then pull out the speaker and there will be an opening. Put your hand down that opening and there will be a nut threaded onto a piece that is attached to the GFX. Take the nut off (i forget it either takes a 10/8 mm socket/wrench) then go back to the outside of the car and pull and the whole thing will pop off.
Old Dec 1, 2003 | 05:21 PM
Transmission: auto
thanks alot, i jus asumed it was glued on haha thanks a bunch.
$750 L98
Feb 1, 2025 02:25 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
New2Chevy
Sep 28, 2015 12:35 AM
tattmann
Sep 27, 2015 05:20 PM
Stryker412
Sep 7, 2015 09:11 AM
