seat cover removal
Old Dec 30, 2003 | 04:24 PM
ssxmac's Avatar
Car: 89 RS
Engine: lo3
Transmission: 700R4 w/ B&M shift improver
Axle/Gears: 3.27 9-bolt posi
seat cover removal
I need to pull the seat cover off of the top half (part where your back goes) of my seat. There is a small tear that im going to have repaired and it requires the removal of the fabric part. I tried unzipping the back and then just pulling the cover off but that didnt work...any suggestions?
thanks in advance....
-chuck
Old Dec 30, 2003 | 07:59 PM
justadba's Avatar
Car: 88 IROC convertible, 88 Sport Convertible---both RED
Engine: 350 TPI in the IROC, 305 TBI in the Sport
Transmission: 700R4 in both
There are 2 rods about 12" to 14" long...one along either side of the seat back where the seam is...you will have to cut off or twist off the hog rings that hold it at the bottom of the seat back...
the rod will then slide out....it has a "bar" imbedded in the seat foam towards the top of the seat back that it slides under.
to replace you will need a couple of hog rings to resecure the bottom of the rods...that have loops in them IIRC...
THINK there may be a rod runs side to side near the bottom of the seat back...where the 'velour' seam is.....can't remember for sure....
Old Dec 31, 2003 | 11:09 AM
ssxmac's Avatar
Car: 89 RS
Engine: lo3
woah little more work then i was expecting....there's that work word again heh.
ill give it another shot. thanks.
-chuck
Old Dec 31, 2003 | 12:55 PM
justadba's Avatar
really not that tough....i replaced my upholestery with an order from Bruce at Hawks Third Gen
took about an hour per seat ....first one took longer ...second shorter due to knowing what was going on....
hardest part was crimping the stupid hog rings......definitely a lot easier if you have hog ring pliers...about 4 or 5 bucks at home depot....
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Out-Cast
Dec 31, 2015 04:40 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
3rdgenparts
Aug 8, 2015 07:09 PM
