Floor Pan
Old Jan 4, 2004 | 10:55 AM
POS Camaro's Avatar
Car: 1986 Camaro Z28
Axle/Gears: 3.73 Posi
Floor Pan
I took off the door trim to figure out where the previous owner routed the power for the amp. When I took off the trim plate on the bottom, I noticed that the spot welds are broken under the trim piece. Is this an easy fix? I plan on getting subframe connectors, how should I fix this properly?
Thanks.
Old Jan 6, 2004 | 01:05 AM
MdFormula350's Avatar
with the suspension loaded (like just sitting on a level surface) you could just tac weld with a mig i would think to re-weld the factory welds, you install subframe connectors the same way with the suspension loaded like on a ride on lift.
Old Jan 6, 2004 | 07:26 PM
POS Camaro's Avatar
So the car is not completely screwed. I can fix this back and won't mess up the frame geometry.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
LC2 TECH
Oct 13, 2015 11:53 PM
88CamZ
Oct 8, 2015 10:29 AM
loud91rs
Oct 5, 2015 10:05 PM
skinny z
Oct 5, 2015 06:23 PM
