More 4th gen swap questions...
Old Jan 4, 2004 | 07:52 PM
sixbanger's Avatar
Car: 87 Firebird (Hasselhoff special)
Engine: 2.8L of PURE STOCK POWER
For my 86 Firebird, which do I need to use: a 93 and up, manual, Camaro or Firebird console?
Old Jan 5, 2004 | 01:42 AM
MNformula350's Avatar
You don't want a 93-96 Camaro console either a 93-02 Friebird or 97-02 Camaro.
Old Jan 5, 2004 | 10:37 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Try and get a 97-02 camaro or firebird one, they are identical and have the flip out drink holder, Must be a manual for to make it a bolt in.
this is a 99 SS Camaro console,
This is a 98 Trans Am console,
Old Jan 5, 2004 | 01:47 PM
tpiroc's Avatar
Car: GM & Jaguar
Engine: Various
Transmission: Various
Axle/Gears: Various
Why is that? Cosmedic purposes or installation purposes?
Old Jan 5, 2004 | 02:17 PM
300hpse's Avatar
Car: 1990 Trans Am
Engine: Lb9
Transmission: factory T5
Axle/Gears: 3.08 limited slip
ugliness is a factor, theyre kinda flat and it has a swuare cupholder thingy, we all know firebirds have always had the better interiors . Installation i imagine is the same.
Old Jan 5, 2004 | 03:53 PM
I have read on the boards that with the cassette holder it is really a pain to install and fit and cut( some one correct me if i am wrong), i prefer the 93-96 Firebird/ ta console my self i don't like the flip out cup holder or the 2 cupholders in the rear of the 97+ console.
Old Jan 5, 2004 | 04:01 PM
Zepher's Avatar
If you have a manual car, the cup holder behind the shifter is useless since it's an ergonomic challenge to shift and have a drink in there, unless you are limp wristed .
Old Jan 5, 2004 | 04:20 PM
Yeah i used to own a 93 Camaro with a manual and my GF would always put a drink in there and i would always bump it when shifting.
I plan on doing something witht eh one in my 96 console, right now i just put my cell phone there or change etc...
Old Jan 5, 2004 | 09:12 PM
sixbanger's Avatar
Sorry I meant to say DASH! Which Dash do you use for a firebird?
Old Jan 6, 2004 | 01:35 AM
Zepher's Avatar
93-02 Firebird dashes are the same,
With the Firebird dash, you can put gauges into the vent holes,
Old Jan 9, 2004 | 03:12 PM
Jesus's F-Bird's Avatar
Car: 83 Pontiac Firebird S/E
Transmission: Borg Warner T5
Wow, i took off my whole dash, and i had like 10% of the cables you have from my 83 F-Bird. Where do they all go !
Old Jan 9, 2004 | 06:18 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
If your removing the factory AC vents to swap in gauges the 2 5/8" Autometers fit PERFECTLY!!
Old Jan 10, 2004 | 12:17 AM
Zepher's Avatar
Most of those wires on the floor are heater control wires, the power window and mirror wires, the fuse box with it's wires, ecm wires. Most of them are going to be spliced into the 4th gen fuse panel, the rest will be removed.
Casey Meyers
Mar 2, 2016 10:46 AM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
sreZ28
Aug 14, 2015 07:48 PM
