window question
Old Jan 7, 2004 | 06:16 PM
DakotaSLT's Avatar
window question
Hey everyone. I picked up a 91 camaro not to long ago, and it doesn't have side windows. I went to pull some from a junkyard, and was told the 82-88 and 89-92 are different. Is this true? I thought all the door panels were the same. Also, are the windows on convertibles any different? Any tips or tricks to getting the windows out and back in? Going to pick them up tomorrow, 80 bucks for the 2 of them. Any advice before then would be awesome.
-Cliff
Old Jan 7, 2004 | 06:21 PM
Agent13's Avatar
Car: 1983 Daytona Trans Am
Engine: LG4
The only differance in the glass between 82-88 and 89-92 is the VATS sticker they put in the lower right corner.
Old Jan 7, 2004 | 06:26 PM
DakotaSLT's Avatar
Hahaha kick ***. One less sticker for the new baby. Anyone have any pointers to make the job easier?
Old Jan 7, 2004 | 10:26 PM
DakotaSLT's Avatar
Anybody?
Old Jan 7, 2004 | 11:12 PM
1WickedSS's Avatar
When you take the window regulator out and its on the ground ( which by the way is a pain by its self!) if you have acess to a welder , weld some 1/4-20 bolts to the regualator, from the back side facing out ( facing into the car) then obtain some 1/4-20 nuts and youll be in busness. this will make re assembly much easier, and you wont have to break your arm to put it back together. other than that its pretty straight forward. I welded mine in the same fashon as I've just told you , andevery time I have to take the door apart I am so glad I did it. Hope I helped you , good luck!
Old Jan 7, 2004 | 11:46 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
I just put mine back in two months ago with the large rivets that the factory uses. No broken arm, no lost nuts or bolts, no dropped wrenchs or sockets. Just a pinched finger from having it in the wrong position on the rivet gun. Oh, and don't remove the motor from the regulator without putting a strong bolt, two large washers and a nut through the holes in the regulator arms. A lot of spring tension there that could just ruin your week. I also have the GM service manual that tells how to do it.
The Trickster!!!!!!!!!!!
Vintageracer
Jan 10, 2020 05:33 PM
pfsteichen
Feb 9, 2016 06:59 PM
RedLeader289
Jan 22, 2016 03:05 PM
redmaroz
Aug 16, 2015 11:40 PM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
