Led im my Camaro 87
Old Jan 12, 2004 | 07:58 AM
Robert76's Avatar
Led in my Camaro 87
Hi,
i know this question been asked several times here, but since i´m not that good at English i hope someone has the patient to answer me.
I want to put led in my 87 interior, or replace bulbs so that i get blue light in my dash and shifterplate.
Or if there is a possiblity to swap buls.
I need links to shops. And names to witch led or bulbs i have to buy in order to achieve same effect simular to attched picture below.
Anything will help/Thanks Robert
Old Jan 12, 2004 | 08:58 AM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
That looks like the same display from the Tech ariticle. If so I have the same LEDs that he used for his install. I may be selling the LEDs that I bought if your interested. I have a total of 15 of them, 2 of which I have already used for the shifter selector which I will include. The reason I may be selling them is because I was going to use them for my 91 Camaro but the blue light shines through the yellow and turns a dull green.
Anyone else use LED's in there 91-92 camaro and if so what color??
Old Jan 12, 2004 | 09:33 AM
StevenK's Avatar
Car: 91 Z28
Axle/Gears: 3.73 Hawks 8.8
The 91 has yellow text (plastic) for the numbers. Blue + yellow = green. Unless you remove the faces and somehow get the yellow plastic out of the faces or redesign the faces with no yellow you cannot get anything but green. There is a thread on this, try searching.
Old Jan 12, 2004 | 10:15 AM
Robert76's Avatar
Yes i´m interested, but how many do i need for my dash and shifterplate?
Old Jan 12, 2004 | 08:03 PM
camarojet's Avatar
Car: chevrolet iroc-z
Transmission: th700r
Hey Robert
I dont want to be rude or something
but that tech ariticle you have,everything stands
You need eleven leds,but if you use the 3000MCD you will need 2/socket for brighter light.
remember that leds are polarity,and use right resistor,if you dont they easy burn out and the last thing, your dimmer will not work
Grafx:did you buy lots of leds??
because you have four into your dash and Robert have eleven!
Old Jan 12, 2004 | 09:00 PM
Robert76's Avatar
No need to worrie, i don´t think you are rude or something.
So i´ll be needing 22leds for my dash+2 leds for my shifter indicator+12 resistor, is this right?
Can you find leds with reistor built in or do i have to do it myself?
And last, were can i buy 3000MCD and resistor?
Robert
Old Jan 12, 2004 | 10:04 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Check the tech article there are 2 distributors mentioned
Old Jan 14, 2004 | 12:58 AM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
Try this, I know its not what you were looking for, but the install is a snap, and you won't need the 20+ leds. I tried the LEDs before and found that they really didn't give the lighting I wanted. I have these indiglo faces in my iroc and absolutely love the visibility.
I hand painted the needles with a bright orange I found in a hobby store. Total was probably like 35 bucks.
Don't get me wrong I love LED's, I have them in other areas of my car, like the gauge pod
its real fuzzy, but you get the idea. Works well in this gauge
Will
Old Jan 15, 2004 | 12:47 AM
305Tiger's Avatar
Car: 1987 Trans Am
Engine: LG4 305 w/emissions & A/C delete
Transmission: "...check!"
Axle/Gears: it's crap...they're stock!
I've just found some 6000MCD LED's available for:
QTY PRICE
1-9 .75
10-99 .65
100+ .60
Buy them here!
For general ordering info, the part number is: 070-003
:hail: the crazy latino :hail:
:lala:
-G
BADNBLK
Nov 16, 2016 09:12 AM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Fronzizzle
Aug 17, 2015 02:52 PM
fonzie85
Aug 13, 2015 11:50 AM
