Hood wont open
Old Jan 13, 2004 | 08:39 PM
Scotty562's Avatar
Car: 2001 SS Camaro
Axle/Gears: I should know this
Hood wont open
Welp, i was testing my subs and i failed to realize they drain the batter very quickely. So needless to say my car didnt start and being the quick thinker i am i proceeded to get ready to charge my battery. So i open the hood... i... hopen the hood.... DAMN HOOD.
It woudlnt open.
When i pull the latch it sounds like it unlached something but nothing opens.
Is this common? and is there any way to get it open? It's never done this before.
Old Jan 13, 2004 | 08:45 PM
Bandit5's Avatar
Stand in the middle, put each hand under the hood near their respective headlights and give it a nice big tug.... it'll open, it just needs a little coaxing.
Old Jan 13, 2004 | 09:05 PM
87cam305's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 305 (LG4)
And then if that works try puting some grese on the latch.
Old Jan 13, 2004 | 10:00 PM
91Zman's Avatar
Car: 1991 Z28
Transmission: 4L60 automatic
Try giving the hood a good light tap with the bottom of your fist(pinky side) near the bend in the middle and about 1ft from the front of the hood.It works on firebirds it may work on camaros too.
Old Jan 14, 2004 | 01:03 AM
OutLaw305's Avatar
Car: 1992 Camaro RS AKA Big Nasty
Engine: Carbed '79 350 block, 360hp/380ftlbs (flywheel)
Transmission: 6speed from an unidentified 4th gen. ask me, ill tell you.
muwahaha, finally i can insert some "real" tech advise. My car does athat all the time. I tell my buddies that it is my camaros magic trick. If you pull the latch in the car.. and it doesnt open, just try shutting your drivers side door a little harder than normal ( well maybe even just normally. We al know bout our heavy a$$ doors). That little jolt is always enough to pop the hood open. Tada ! ad thats my magic trick.
Old Jan 14, 2004 | 05:47 AM
Scotty562's Avatar
Car: 2001 SS Camaro
lol magic trick, i'll go give all this suggestions a try, i allready tryed the first one which was yanking on it (think i pulled something)
Nothing worked im glad its shacked up for the winter or i'd be in a real fix. The old Wrangler never had this problem
Old Jan 14, 2004 | 07:53 AM
ddn69's Avatar
Car: 92 caddy PIMP
Engine: 4.8
Transmission: i dunno
my hood is a bitch sometimes. The previous owner said sometimes hed drive around just to get it open. hehe. anyway I usually hit it pull the hood release thing a few times again hit it again till it opens usually works in a few shots. Then spray some wd 40 into the latch.
Best of luck
Nate
Old Jan 14, 2004 | 09:34 AM
87cam305's Avatar
Engine: 305 (LG4)
Try having someone lift up on the hood by the headlight pokets as you pull the release. If that don't work try to get under the bumper and see if the cable is still in place. Or maybe you can pop it from undreneath (I have done this a couple of times)
Old Jan 14, 2004 | 10:46 AM
Jesus's F-Bird's Avatar
Car: 83 Pontiac Firebird S/E
Transmission: Borg Warner T5
Hahah, thats what i have to do to ! I have a bird, and thats how i fix mine. My GF car does the same thing, but hers is a Camaro, and what i do for that one, is i hit the front of the hood (pinky side down of course) and i hit it about a half foot to a foot to the left of the middle. Hit it once or sometimes twice and it opens up. Otherwize jack up your car, and hit the release with a screwdriver and if needed a screwdriver/hammer combo. Works like a charm.
Old Jan 14, 2004 | 12:46 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
If all these tricks fail, you might have to crawl under the front of your car and work the mechanism by hand.
Old Jan 14, 2004 | 01:29 PM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Transmission: 700-R4
Another suggestion!
Go to the front and push down so the hood will re-latch and try pulling the release again. It might take 2 or 3 times to get it to pop open. after you get it open and spray the hell out of it, pop the spring coil off the hood and stretch it out about an inch. They get weak as time go's by and they don't work so well! It cured my problem!
Old Jan 14, 2004 | 02:23 PM
Scotty562's Avatar
Car: 2001 SS Camaro
i got it open woooo
turns out i wasnt pulling hard enough
the 1st or 2nd post was right, it just needs a little coaxing lol
I love it
Old Jan 14, 2004 | 04:57 PM
Bandit5's Avatar
Hehe, told ya. And I said a nice big tug, so you should yanked it till it hurt your arms the first time!!!
Old Jan 15, 2004 | 08:01 AM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
i just tug on mine, good thing i'm not strong enough to bend steel
Old Jan 15, 2004 | 09:48 AM
GTA4ME's Avatar
Car: 1988 Trans Am GTA Notchback
Engine: 305ci, 5.0L, TPI, HO
Transmission: Borg Warner T5 5-Speed
Axle/Gears: 9-Bolt Positraction Rear w/3.45 Grs
I'm glad you got it open, kind of hard to work on your car when the hood won't open.
Hotrodboba400
Dec 10, 2019 07:07 PM
neilb
Sep 15, 2015 05:06 PM
luvofjah
Sep 3, 2015 07:08 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
SlowAZ28
Sep 2, 2015 05:19 AM
