shifter trouble
Old Jan 19, 2004 | 12:21 PM
Dingley's Avatar
Car: 1986 Pontiac Trans Am
Engine: LG4 305
shifter trouble
this little plastic peice (circled) came out of the spot it is suppose to be in the metal shifter plate. how do i get it back in... it doesn't seem to fit.
Old Jan 19, 2004 | 01:03 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
It's been awhile since I have done this, but I seem to remember that you just line up the piece with the round hole and push it in place towards the front of the car. There should be a tang on the top that lines up with rectangular opening in the bracket to keep it straight.
The Trickster!!!!!!!!!!!!
Old Jan 19, 2004 | 05:04 PM
Dingley's Avatar
Engine: LG4 305
well, i got it to sit in the circle opening now. but i found out why it popped out in the first place. the two clips that hold it in place when you shift from another gear INTO park broke off. you can shift out of park however. so, i used a adhesive sealant to stop it from backing out, do you think this should work?
Old Jan 19, 2004 | 05:53 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
It is a temporary fix at best, however I would strongly suggest spending the bucks to buy a new one. I don't think that you would like the nightmare of it popping out again at the wrong time.
Old Jan 19, 2004 | 05:56 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
i agree if your going to do something do it right the first time
Old Jan 19, 2004 | 09:25 PM
Dingley's Avatar
Engine: LG4 305
how do you install a new one of those? i don't even know where the other end goes to.
Old Jan 19, 2004 | 09:49 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
I am sending you the information from the GM service manual by e-mail.
mcfastestZ28
Oct 5, 2015 07:12 AM
ndndndnd
Sep 28, 2015 08:00 AM
