'91-'92 Firebird Nose Piece question
Old Jan 19, 2004 | 11:05 PM
Derth Deboblo's Avatar
Car: '91 Firebird (blown apart)
Engine: *cough*BOAT ANCHOR*cough*
Transmission: Slushbox
Ok, my J-yard fresh '91 Bird has a totally thrashed nose. It's torn and all sorts, crap really. Anyways, I'm looking to find a nice used one and I'm wondering if it depends if the used one has to have come with the factory foglights or not (I do have them on the '91 by the way)?? If you can help me on this, it would be great!
Derth
Old Jan 19, 2004 | 11:10 PM
Agent13's Avatar
Car: 1983 Daytona Trans Am
Engine: LG4
Nope. They are all the same
Old Jan 20, 2004 | 10:09 AM
GarageToys's Avatar
Car: 89 Iroc Hardtop
Engine: LB9 w/G92 Pkg
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt, 3.45
WRONG. there are 2 types: ground-effects type and non-ground effects type. The Formulas and some base model Firebirds did not have ground effects. They did not have foglights either. I believe you will need the type with ground effects.
Old Jan 20, 2004 | 02:25 PM
Orinackra's Avatar
Car: 06 SRM M6 GTO, 98 Grand Prix GTP
383 is right, buuut, if your feeling brave and you pick up one without the fog light holes, you can cut them out. I think MDFormula350 did that to his. But you still have the obvious problem of no gfx for the front.
Old Jan 20, 2004 | 02:30 PM
Agent13's Avatar
Engine: LG4
Old Jan 20, 2004 | 04:42 PM
Yeah, my '91 has factory G/F's on it. I assume that the g/f on the 'Bird nose cant be changed (I know you can switch out the lower lip on a Camaro). How hard would it be to cut the foglight holes? MDFormula350...help
Old Jan 20, 2004 | 04:50 PM
GarageToys's Avatar
If you still have the ground effects pieces between the nose and the front tire- you need the ground-effects-type bumper cover to make it look right. Otherwise you're going to have a gap where the GFX meets the bumper cover.
If those pieces are broken or missing (as most of them are), you can probably eliminate them and go with the non-ground effects style bumper cover. Since the 91-92 GFX come down to a point behind the front tire, it really wouldn't look that bad.
<edited to remove redundancy...>
Old Jan 20, 2004 | 05:37 PM
Heh, how'd you figure that they were gone
*sighs*
Well, I guess I'll have to find the g/f nose and the g/f on the fender. Damn all the little stuff....damn you
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Thomas
Oct 3, 2015 05:34 PM
redmaroz
Aug 16, 2015 11:40 PM
