Driver's side door won't open
Old Jan 24, 2004 | 09:42 PM
NastyL98_T/A's Avatar
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
well you can call me a duma$$ if you like, but I locked my keys in the car this morning. Had to use a coat hanger to get into it. I managed to get in there and pull the switch forward, but the door wouldn't open. Ended up having to pry the window out enough to pop the t-top out. Now the problem is that even thought the it's unlocked, the door wont open from inside or out. I can hear the mechanism moving in there, but no open. If I slide the lock switch, I hear and feel it moving. Any ideas how to fix this one? It sucks climbing over to the pass. side
Old Jan 24, 2004 | 11:42 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
my guess is when you were messing around with the coathanger, you unlatched the door mechanism which means its floating around and your door cannot be opened.
your best bet is to take off your door panel and just put it back on
Old Jan 25, 2004 | 10:30 AM
89cmrodriver's Avatar
Car: 08 Sierra, 08 Silverado, 91 z28
Engine: 5.3, 4.3, 5.7
Transmission: autos
yup thats sounds about right, does the inside door handle feel like its pulling anything?
Old Jan 25, 2004 | 01:21 PM
Faded's Avatar
Car: '91 Firebird
Ha! That's how I had to get into my car last time I locked myself out too. Even with the door slightly ajar, I could still barely get my arm in the window, and I've got pretty skinny arms.
IMO, the best way to get in is with a long rod. Poke it through the window on the opposite side of the door you're trying to open, and then push it against the lock. Works great.
Old Jan 25, 2004 | 03:05 PM
Daishi's Avatar
Car: 1988 Camaro IROC
Axle/Gears: 3.27 9 bolt posi (non 1le)
Solution:
Keep a spare key in your wallet, or you can tape a key inbehind your license plate or keep it hidden in your gas cap
Old Jan 25, 2004 | 03:30 PM
Engine: LB9/383
if I pull the handle (inside or out) to try to open the door, it feels like it's still connected. We'll see. I'm gonna go mess with it now.
1992 Trans Am
May 10, 2023 07:19 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
BlackTopKing
Aug 19, 2015 12:13 PM
blacksunshine'91
Interior Parts Wanted
Aug 10, 2015 12:04 AM
