hatch motor problem
Old Jan 27, 2004 | 10:39 AM
Kingdomofmadnes's Avatar
Car: Camaro z-28-1992
Engine: 305tpi
Transmission: th700r
hatch motor problem
i have a question about the hatch motor, do all hatch motor from a 3rd gen works in every 3rd gen car?
i have read about my camaro 92 is not the same motor as the others 3rd gen cars
But if you look at ebay those they sell always stands 82-92
anybody out there who knows?
i dont know if this is right thread to post this question,but i try :-)
Old Jan 27, 2004 | 11:45 AM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
I think they changed the design. You might want to check out Top Down Solutions they offer a good array of hatch pull down parts.
http://www.top-downsolutions.com/ind...ed1e8f383f1bc6
Old Jan 27, 2004 | 01:57 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
There are two versions of hatch pull-down unit used in the ThirdGen's. Actually there were three, since there are some construction differences between the 1986-87 and the 1988-91. But since they are interchangeable by simply swapping the plug on the blue wire, considering them from a fit and function basis, there are just two. The 1986-91 cars have a hatch pull-down unit with a large metal frame. I manufacture and supply most of the parts needed to repair these units. There was a change mid-year in 1991 to a smaller unit with a tan colored injection-molded plastic frame. The only part that was carried over from the old model to the new was the gear (called a gear nut) that is turned by the worm drive of the motor and raises/lowers the latch portion. I have a few used units in stock and plan to disassemble, clean and rebuild them. I only have the gear nut and reversing switch as new replacement parts so far.
Lon Salgren
Top-Down Solutions
madsv1000
Aug 20, 2015 06:45 AM
stalkier
Aug 13, 2015 12:59 PM
1nastygta
Aug 8, 2015 07:38 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
