Lower shift boot
Old Jan 31, 2004 | 03:32 PM
Bobbyz's Avatar
Car: 87 IROC Z "ZZ4"
Engine: 350 "ZZ4"
Transmission: ck performance th400 3000 stall
Axle/Gears: 3:73 10 bolt
Lower shift boot
Hey all sorry if this is in the wrong section.
i just installed a hurst shifter in my 85 z28 and i had to purchese a new lower shift boot. i noticed the shifter sits a little higher then the stock one so when i went to install the shift boot it was fully extended instead of being sorta flat and now the car is poping out of 1st and 3rd gear
with the boot on the stick is tight and when i took it off it felt fine
i tried pushing the boot as low as i can below the handle bolts to make it flatten out but it is still sorta high up.
i thought maybe it was beacuse the boot was new and the rubber was stiff and maybe in the summer it will soften up.
anyone have this problem? if so how did you fix it?
thanks
F-body driver
Mar 6, 2023 11:44 AM
J-money
Jan 4, 2019 09:45 AM
BOOT77
Sep 5, 2015 03:55 PM
tonys91rs
Sep 2, 2015 07:07 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
