Removing front pass fender, need help.
Old Jan 31, 2004 | 05:50 PM
JimmyG-91Z's Avatar
ok I got everything off (I think) except for what attaches to the front bumber. Is there a way to take off the fender without removing the front bumper?. From what I can see there are 4 bolts that connect the front fender to the bumper. I snapped the 2 bottom ones already trying to get them off (Damn corrosion). I can't reach the top one unless I pull off some major contortionist tricks. and the other one moves but doesn't seem to be doing anything. After I did all this I realized that I probably should of taken the front end off.
So am I a complete dumbass or can I be saved?
Any help would be greatly appreciated.
JimmyG
Old Jan 31, 2004 | 06:06 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
You can use about 2 feet worth of extensions and go in through the wheel well to get the top two nuts. The studs they go onto are fixed to a plate in the front cover.
There's also a small L shaped bracket about midway up on the front of the fender...it attaches to the front part of the body.
Old Jan 31, 2004 | 06:12 PM
You say the second one down is just spinning? That could be trouble...you may have to get a nut-splitter up there to remove the nut. Or carefully hacksaw the stud, going in between the fender and bumper cover.
JimmyG-91Z's Avatar
Yeah I was using extensions, but I still can't reach the top one, the top of the fender gets in the way for me to line it up right.
but I'll try to contortionist crap if you saying I don't have to take off the front cover
Old Jan 31, 2004 | 06:15 PM
JimmyG-91Z's Avatar
I imagine I can figure out a way to get the second nut, so it's jsut these two nuts and the L shaped bracket and the fender should come off?
Old Feb 1, 2004 | 12:53 AM
Gotta make a correction to the first post. The two upper nuts go onto studs which screw into the fiberglass headlight bar. That's probably stripped the 'threads' out of the 'glass. There's a 'ring' around the stud which fits between the 'glass and the cover. From the inside, you may have to cut a section of the cover out to let the stud pull out. I'll try to get a pic or two tomorrow to show you what I mean...
Old Feb 1, 2004 | 11:26 AM
heavy_chevy29's Avatar
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
for the top nut use a 10mm deep socket with a swivle(sp) between the socket and the extensions. that should work.
Old Feb 1, 2004 | 05:34 PM
Charged350's Avatar
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
Yeah, get that bracket off, adn make sure you remove the gfx from the nose that attach tot eh fender, and make sure ou remove the one behind the tire all the way down underneath the ground effect, they are usually all bent up and crushed cuz dumbasses jack cars up at that punch weld...
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
kyleb24
Aug 15, 2015 08:24 AM
wruiz
Aug 11, 2015 02:59 PM
3rdgenparts
Aug 8, 2015 07:09 PM
