oh no.. dropped a screw. Where does this go?
Old Feb 1, 2004 | 12:27 PM
OutLaw305's Avatar
Car: 1992 Camaro RS AKA Big Nasty
Engine: Carbed '79 350 block, 360hp/380ftlbs (flywheel)
Transmission: 6speed from an unidentified 4th gen. ask me, ill tell you.
well while i was taking my dash off, i dropped a screw and a socket down here. ARG! Where would it be now?
Old Feb 1, 2004 | 12:32 PM
NastyL98_T/A's Avatar
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
Gone forever. Good luck finding it. Try fishing around with a magnet, otherwise you'll have to do some serious dismantling of the dash to get inside the vents.
Old Feb 1, 2004 | 12:59 PM
89cmrodriver's Avatar
Car: 08 Sierra, 08 Silverado, 91 z28
Engine: 5.3, 4.3, 5.7
Transmission: autos
better off buying a new socket.
Old Feb 1, 2004 | 03:18 PM
87rediroc's Avatar
Car: 87 Iroc (summer only)
Engine: 5.0 TPI
Transmission: 5 speed
A magnet might help your cause. When I dropped something in a similar spot, not a vent though, it found its way to the floor below. Maybe by posting, some of my luck goes your way. Let us know if you find out where the vent leads...
Old Feb 2, 2004 | 02:30 AM
90firebird's Avatar
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
dont give up after you fish around for them the first time! if nothing comes up, drive around and listen for them making noise.... use that to help you fish for them again if you're still up to it. or, if your luck is good, they might just pop out underneath somewhere and the problem will be solved... well, best of luck!
Old Feb 2, 2004 | 06:34 AM
easySPEEDcamaro's Avatar
Car: 1992 Camaro Z28 Anniversary Edition
Transmission: Borg Warner 5-Speed
hahaha this is so funny...
mainly cuz it always happens to me
Old Feb 2, 2004 | 06:55 AM
acescarrsRS's Avatar
Car: 89 RS
Engine: 383 in building process
Same here. Don't know how many screws & sockets I have lost to those vents
Old Feb 2, 2004 | 08:30 AM
Z dude's Avatar
Car: 1991 Z-28
Engine: TPI
Transmission: 5-speed Rear:3.73
reminds me of the movie "Tommy Boy" when chris farley
dropped all the M&M's down the vent of his buddies classic car
Old Feb 2, 2004 | 10:26 AM
Stokdd's Avatar
Car: Yellow '92 Formula
Transmission: A4
Unless you have a super-skinny 5ft magnet, you won't see them again.....Believe me, I've tried!
Old Feb 2, 2004 | 02:45 PM
OutLaw305's Avatar
maybe a magnet tied to a string.....
ill try it this weekend when i go back home
Old Feb 2, 2004 | 09:32 PM
thecoolone's Avatar
Car: 89 GTA
You'll find it..... when you replace your heater core.
Old Feb 3, 2004 | 02:06 PM
89V6FBIRD's Avatar
Car: 1999 Pontiac Trans Am
Engine: LS1 - 346 ci
Make sure the string you use is pretty strong... you'd hate to lose your magnet!
Old Feb 3, 2004 | 02:11 PM
Dr.NickRiviera's Avatar
Car: 1987 Trans Am
Engine: tree-fiddy
Well I've dropped a bolt down the exhaust pipe once when i had the manifold off. I used a magnet attached to a toilet snake.
Old Feb 3, 2004 | 02:54 PM
Freeze's Avatar
Car: 1992 Firebird
Engine: 3.1 V6
I did the same thing. A magnet got it out.
Old Feb 4, 2004 | 12:42 AM
grngryoutmyway's Avatar
Car: 92 Z28
Axle/Gears: 3.73 10 bolt
arr Ive tried this a million times...eventually other stuff just starts making more noise than the screw in the vent and you get over it...try having your exhaust resting on part of your rear end...evey time the exhaust makes noise...well it makes alot more noise! not to mention every little bump in the road ahhhhhhh
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
