For those who have been towed...
Old Feb 3, 2004 | 01:18 AM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Yes, I know it is embarassing, but I have to know this:
My uncle was over one day when I first bought the 'bird and he gave me some strange advise: "If you ever have to be towed with this car, you will either open the hatch or have to replace it when the trip is done." Is this true, and do SFC's make that much of a difference in this case?
Old Feb 3, 2004 | 03:54 AM
semiller26's Avatar
Car: 1986 Trans Am
Not true. However I will say this the only time I allowed her to be towed not on a flatbed was when I threw the A/C belt(cut through the radiator hose) in Oakland at about midnight. There was no way I was leaving her there. I had her towed into the Orinda BART station (safer area). The hatch was fine though. You should not have a problem.
Old Feb 3, 2004 | 06:51 AM
Mathius's Avatar
Re: For those who have been towed...
I've had mine towed at least twice I think, no problems. I'm certain on the one time, but I thought it was more than once.
Mathius
Old Feb 3, 2004 | 12:08 PM
MizfitCreations's Avatar
Car: 87 Camaro LT
Engine: ZZ4, AFR195, XR276-HR
Transmission: 700R4, Transgo
My car was towed out of my own apartment complex, stupid Drivers Not sure what kind of truck they used but I haven't had a problem.
Old Feb 3, 2004 | 02:19 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
i have had my litlte precious towed over three times (all of which were on a flatbed though) and i havent had any problems yet. except scraping the damn front air dam when i was backing it off!!!
Old Feb 3, 2004 | 03:35 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Mines been towed 3 times, no problems at all, here is the 3rd time it was towed, had to tow it since open headers with no y-pipe was too loud.
Old Feb 3, 2004 | 04:05 PM
Flyersman29's Avatar
Car: 1989 Chevrolet Camaro IROC-Z
rollback once when i blew the rear up.
Zepher... man when i did my headers and had headers and y pipe only i drove it for a week till i could get it in the shop...
Old Feb 3, 2004 | 04:17 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
I use the drag car trailer when i need/want a tow, which doesn't happen much, but I had a starter go out once, and right after I bought the car I had a wheel bearing go bad and I didn't want to mess up the spindle, that was the only time I had to use a wrecker, but it was a roll back. Rule of tumb is to only use roll backs.
Old Feb 3, 2004 | 06:12 PM
Zepher's Avatar
Having a y-pipe makes it quieter. I had no y-pipe so it was pretty loud.
Old Feb 3, 2004 | 06:44 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
When I installed my headers, I drove it to the shop with open headers
It was only two miles, but man was it loud.
Old Feb 3, 2004 | 09:30 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
ummm nope
well i have towed many cars in my side job while in school. and i have sling towed camaros, not the prefered method but if ya know how to rig it nothing gets damaged, i have wheel lifted many and flat beded a ton. never ever seen or heard of any problems. i actully prefered the wheel lift, the cars sit so low that there is a slight chance of damaging the nose when loading on a flat bed truck. boards must be used on most cars to get clearance.
so i would say don't worry if you need to be towed.
Jeffw
Old Feb 3, 2004 | 11:01 PM
CaysE's Avatar
Had mine towed once when the starter went (right after I got it, no less). They lifted the rear wheels. I was worried as hell, but no problems. I got SFCs not too long after, which doesn't really matter much in this case, but get them anyway. They really do help a lot.
Old Feb 4, 2004 | 03:03 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
shouldn't have a problem
Old Feb 4, 2004 | 10:45 PM
TheNutzZ28's Avatar
Car: 89Iroc Vert, 86 Iroc/Z28
Engine: 383carb, 350 TBI
Transmission: Th350, 700R4
Axle/Gears: 3.23 posi disk, 3.42
OK those were the nice stories, I learned the hard way. My fuel pump went out and had to get towed. Got a flat bed out and my rear of the car was face towards the front of the truck. About 3 miles later my rear louvers flew off the car they decide to get airborn then land on the road. Got pulled off to the side of the road only to watch a full size dump truck drive over the metal louvers. I say your fine if you do not have louvers on a car while pointed towards the front of a truck. Just had to say the store....and I got money from the tow company to replace the louvers.
Old Feb 4, 2004 | 10:52 PM
Engine: 2.7L V6
Axle/Gears: 4.41
That is so not funny. I am not laughing (much!). My mom's car has one of those wheelchair carriers on the top of it (was grandma's car before she died) and we were going down NYS I-490 on the way home. Just before Churchville, the fiberglass over the opening portion of the carrier decided to destroy all of its rivets and fly off. Luckily, it landed at the side of the road at a point where one can turn off and rest or wait when stuck in snow, so nothing ran it over.
vicg1
Jan 10, 2018 11:29 AM
Psycho_91Camaro
Southern California Area
Aug 11, 2006 03:35 PM
