converting hard top to a t-top
Old Feb 4, 2004 | 05:27 PM
transam84's Avatar
well I have a dilema here. I bought an 84 Firebird mainly for parts. I have also been looking for quite a while for a straight rolling chassis that I could have caged and tubbed. my problem is this. the parts car I bought has fixable rust from what I can see so far and it looks like this car would be great for a pro-street project that I REALLY want but my only problem with the car is it is a hard top and I really want my future pro-streeter to be a t-top car. is this a straight forward swap for an experianced body man??? please don't tell me that the hard top is better for a pro-streeter b/c is will makes the car stiffer, T-Tops and F-Bodies go hand in hand and the Trans Am I drive right now is a T-Tops and I love it that way.
Old Feb 4, 2004 | 06:44 PM
MNformula350's Avatar
As i understand it it's a lot of work and really expensive, and a lot of people will say it's not worth it.
Old Feb 4, 2004 | 08:01 PM
labrat's Avatar
Car: 87 IROC-Z
Transmission: automatic
Not worth it. Buy a beater T-top car, turn it into a prostreet car, you will save money.
Old Feb 4, 2004 | 08:24 PM
3GTAs1TA1Z28's Avatar
Car: 85 87 87 91 92
Engine: 305 TPI 350 TPI 350 Carb
Transmission: B/W T-5 and 700R4
Aside from the cost. The frames are built differently to handle the T-tops versus a solid hard top
Attached Thumbnails converting hard top to a t-top-my-3rd-gens-front
Old Feb 4, 2004 | 08:51 PM
transam84's Avatar
are you 100% positive the frame is diff??? it sure looked the same to me unless the frame was made with a smaller guage steel.
Old Feb 4, 2004 | 08:59 PM
Car: 85 87 87 91 92
On The Third Gen's I am not 100% sure But on the Second Gen's I know they are different. Check with your local frame and or body shops and they should be able to confirm it.
Old Feb 4, 2004 | 10:00 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
8-9000 to do the conversion. You have to cut the top off a t-top car at the b pillars and the firewall, and weld it in. There is a place that does this, they specialize in building kitt/karr replicas. Mikes custom kitts I think is the name of it.
best is to buy a striped t-top body and transfer it over, check ebay you should be able to find a running v6 t-top car for under 1k on there..
The frame on a third gen t-top vs a hard top is the same, and since you are making a prostreet you will have a roll cage so structually there isn't a problem. Only other difference between them is a little wedge in the door frame to tighten up the door.
I'llrocya
Exterior Parts for Sale
Nov 11, 2015 05:45 PM
yankeecarman
Convertibles
Aug 23, 2015 07:47 AM
qz6lwp
Aug 20, 2015 08:10 PM
LittleFranks
Aug 20, 2015 03:55 PM
