Installed my high rise spoiler
Old Feb 4, 2004 | 10:53 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
I finally installed my high rise spoiler. i just need to weld the holes shut then I will be done. I got a decklid from a 91 Z so that mad the install easier. Taking the old decklid was a pain in the a** though. Gonna get it painted in a couple months, its gonna be black . Got some grid taillights on the way and will probably get the windows tinted and an alarm in the next couple of weeks. Thought I would take some pics since it was actually nice today!
Old Feb 5, 2004 | 12:18 AM
Thirdgen86TA's Avatar
Once you get those tailights tinted it will look sweet
Old Feb 5, 2004 | 01:36 AM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
I disagree, I find blackouts ugly, I like the stock look.
Old Feb 5, 2004 | 10:52 AM
Daishi's Avatar
Car: 1988 Camaro IROC
Axle/Gears: 3.27 9 bolt posi (non 1le)
Blackouts are nice, Just try to get the more square lookin ones than the bubbly ones
Old Feb 5, 2004 | 11:19 AM
llvll4l2c91350's Avatar
i love the look of the high rise wing.
get the grid lights and it'll look much better.
Old Feb 5, 2004 | 04:49 PM
GarageToys's Avatar
Car: 89 Iroc Hardtop
Engine: LB9 w/G92 Pkg
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt, 3.45
Where exactly does he say he's tinting the taillights?
The car will look good black.
Old Feb 5, 2004 | 06:45 PM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
I'm indecisive as to wether or not I like that look... I mean, the 82-84 GFX with the highrise.
Looks like before you paint, you should buy my set of 85-90 GFX!
Old Feb 5, 2004 | 06:52 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Yeah I will probably get newer style gfx before I get it painted. It would be nice to get the 91-92 but they are so expensive! How much are you selling yours for?
Mike
Old Feb 5, 2004 | 07:15 PM
Dante93GTZ's Avatar
Axle/Gears: 3.23:1
Make an offer. At present, I've got the sides and complete rear... GREAT shape, no tears cracks, or deformaties (sp?).
Old Feb 5, 2004 | 11:31 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
it's weird how just adding a 91-92 Z28 highrise spoiler to an 82-84 Z28 makes it look...it looks good...but it still kind of looks "naked" because of the ground effects. The highrise and the 91-92 ground effects work very very well together...it's coming together great! good luck
Old Feb 6, 2004 | 10:22 AM
Wootah's Avatar
Car: 88 Iroc-Z
Engine: 355ci
Transmission: WC-T5
whjere did you get a 91 decklid at?? im gonna install mine while my cars down for a while during the engine swap, so ill have plenty time to get it done.
Old Feb 6, 2004 | 10:35 AM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
I got it off of this sites classified ads I just posted a wanted ad and had a couple people email me.
Old Feb 8, 2004 | 05:13 AM
mastertrixter's Avatar
Car: 82 z-28
Engine: L69
Transmission: muncie T-10
hey man this may be a wee bit off topic, but i was wondering if u had a better pic of your exhaust from the back. A ground shot would be awsome.
Old Feb 9, 2004 | 10:20 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
here are some pics man. do you want a pic straight back? all the ones i took got messed up because of the sun but i will try and get a good one tommorow. the tips are the ones that come with the flowmaster catback.
Old Feb 10, 2004 | 01:35 AM
Car: 82 z-28
Engine: L69
thanks man, that exhaust looks great, keep up the good work.
Old Feb 10, 2004 | 05:23 PM
VERTIGO Z28's Avatar
Car: FBODYS
Engine: ALWAYS 8'S
Transmission: ALWAYS MENTAL
Axle/Gears: RUSTY AND BRAND NEW
Looks good. From the pics it also looks like the allignment perfect. Did it give you any hassle?
Old Feb 10, 2004 | 08:42 PM
CamaroEFI's Avatar
i plan on putting a high rise wing on my 91 RS also. what exactly did you have to do to install it? can i use my decklid instead of buying a z28 decklid
Old Feb 10, 2004 | 09:35 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Yeah the alignment is pretty good. It wasnt really that hard either. There is a lot of room to play with when the decklid isn't fully tightened to the glass. Here is a tip I used from the site. Before you fully tighten everything down either line it up yourself on the outside or have someone do it for you. Then climb in your car and just lay on your back to fully tighten them. That way the alignment is perfect
Old Feb 10, 2004 | 09:43 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Here were my steps:
-Remove plastic panel that covers the bottom of the decklid
-Loosen the bolts that secure declid to the glass
-Remove 2 black screws that come of a black metal extension connected to the glass
-Unbolt the bolts that secure the struts. The glass weights a ton too!
-Hard part, removing old decklid. Its now only held on by a type of sealant. I used a long utility blade knife. Take your time and be patient so you dont cut yourself like me
-Once you get that off just clean the glass up and put new sealant on there
-Put new decklid on and align it
-Then just do the first couple of steps in reverse.
-Put your high rise spoiler on then say damn that looks good
It will be different for you if you just use your original decklid. You will just have to fill in all your original holes and drill new ones for the highrise spoiler. If you can weld then you should probably go this way.
Mike
Old Feb 10, 2004 | 10:58 PM
Car: FBODYS
Engine: ALWAYS 8'S
Thanks for the good info breakdown
This should make installing mine go smoothly. I like the two person trick, never thought of that.
LilHot
South Central
Apr 13, 2026 11:46 PM
Frozer!!!
Jan 19, 2024 04:55 PM
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
Hello, Michael
Aug 20, 2015 03:19 PM
camaro_rs350
Northern California
Aug 18, 2015 12:38 AM
