A Problem with T-tops
Old Feb 7, 2004 | 01:15 AM
3GTAs1TA1Z28's Avatar
Car: 85 87 87 91 92
Engine: 305 TPI 350 TPI 350 Carb
Transmission: B/W T-5 and 700R4
My 92' GTA has the lexan t-tops and the paint or the tint on the outside has started to come off.. It started with a 1 inch section and then 2 inch over time it keeps growing right now about half the t-top tint or paint has come offand it is always been erfectly straight lines from front to back. Anyone know why this is happening?
Is there anything to fix it cause its looking like.....well you know.
Old Feb 7, 2004 | 03:44 AM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
scrape the rest off and go get some tinting material and re-do it yourself.
Old Feb 9, 2004 | 12:44 AM
Car: 85 87 87 91 92
Yeah, Grand idea however its on the outside, The tint wouldn't last
Old Feb 9, 2004 | 01:19 AM
1984TransAmH's Avatar
Car: 1998 Firebird
Engine: 3.8L V6
That's why you tint the inside.
It looks the same, just use the really dark stuff, like the Limo 15% or lower.
Old Feb 9, 2004 | 10:05 PM
Car: 85 87 87 91 92
Have you ever seen 2 t-tops one original and the other tinted on the inside.. It doesn't look that great...I am going for show look not tacky.
Old Feb 10, 2004 | 05:43 AM
1gta2c's Avatar
I have the same problem with my 91. The best way to do this is sand it down with 1000 grit sand paper and then you are giong to have to buff out the scratches. I am using buffing compounds to do this. If you find it too bright in the car you might want to buy t-top shades. Then use car wax to keep it new. My 2 cents.
Old Sep 19, 2004 | 12:03 PM
ScrapMaker's Avatar
Car: 2000 Trans Am WS6 (Black)
mine are tinted on the inside on my '90, and they look great, aside from the scratches they've accumulated... I'm thinking of having them redone.
Old Sep 19, 2004 | 02:10 PM
1tinindian's Avatar
Car: 1983 WS-6 Trans Am
Engine: 1999 L31 5.7 Vortec
Transmission: 5 speed
Axle/Gears: Auburn Limited-slip w/3:73 gears
1gta2c, has got the answer- only that I used 1500 grit sand paper on my brothers 91 Lexan tops.
When it is sanded to the point where none of the delamination is visiable, I used a power buffer, the same one used for buffing paint jobs, and a very mild compound, until the tops looked as good or better that new.
That is, until one blew off and broke in two
Old Sep 20, 2004 | 11:02 AM
ScrapMaker's Avatar
can someone explain the difference between the lexan tops and... NOT lexan tops?
mine appear to have a film on the inside of the t-tops... you normall cannot see the edge of the tint unless you take them off
Old Feb 11, 2005 | 01:03 AM
Guy's 89's Avatar
Car: 89 IROC T-Top
Engine: 5.7 TPI
ScrapMaker,
Only difference I know between the two types of tops is that Lexan is lighter and a bit less, well, scratch-resistant. I can't imagine any of them are tinted on the outside!? All auto windows in my experience are tinted on the inside--it seems to make sense.
I have glass tops which ALSO have some scratches in the tint like yours. They're very small, and I can't see removing all the tint and re-tinting. It's been awhile since you posted about re-doing yours. Did you by chance find some kind of touch-up that would hide the scratches without a complete overhaul?
Or maybe you've had them done already. If so, was it very expensive?
Old Feb 11, 2005 | 01:06 AM
ScrapMaker's Avatar
well I guess I have glass... since they are so damned heavy, and no I haven't had them redone... I would not bother "touching up" tint, because it would probably look like crap in my opinion. You can get a quality tint job for your entire car for $99.... I bet I can get my t-tops done for like 30-50 bucks.
1Aauto
Sponsored Vendors
Aug 26, 2015 02:14 PM
1Aauto
Sponsored Vendors
Aug 24, 2015 03:40 PM
g.l.mos
Aug 22, 2015 12:02 AM
Penultimo
Camaros Wanted
Aug 20, 2015 08:42 PM
qz6lwp
Aug 20, 2015 08:10 PM
