Where can I get sheet of aluminum at?
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
Hey Guys, I'm going to remove my cut-out switch panel and make a new one. I'm going to go ahead and remove the ashtray lid, and install a piece of polished aluminum with my cut-out switches mounted there.....I always have my ashtay lid open....and I think it would look better if my switches were "flush" with the rest of the console.....but..I don't know where to get just a sheet of aluminum from.....anyone know where? thanks
Car: 1992 RS
Engine: 406 Stealth Ram
check http://www.eBay.com, you'll find a crapload of scrap metal. I've purchased some before, usually high quality stuff!
Scott
Scott
Car: GM & Jaguar
Engine: Various
Transmission: Various
Axle/Gears: Various
What I've used in the past is the little sheet of aluminum that come with RadioShack project enclosures. It's a nice piece that comes with all their enclosures as an aux lid. It has a pretty nice finish on it, decent thickness, and easy to work with. Just a suggestion for what I've had good luck with in the past.
Engine: 5.7
Originally posted by grngryoutmyway
How do you cut the aluminum sheet?
probably just a jig saw or a band saw with a metal blade....shouldn't be to bad..
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
tin snips.
you can get a pack of all 3 cutters (left, right, and straight) for cheap if you look around.. may not be the best ones, but if you're only cutting alum or really thin steel sheet, they'll work for a long time.
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Use a dremel to cut it if you have one, it wont bend the metal like snips or a saw will.
Car: 92 Z28
Axle/Gears: 3.73 10 bolt
Engine: 5.7
I'm just going to be using a bandsaw at the college I go to....I have like 10 million metal classes...so..using the tool won't be a problem
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
If you have any shops around that sell body panels for dirt track cars, that'd be the place to go, we paid $18 for a 2'x5' section. Any color you can imagine, we just installed some chrome aluminum for a flush mount bed cover on the S-10, wow is that stuff shiney, ought to make for some serious sunburns and instant blindness this summer.
I am lucky enough to have a set of electric shears that are indisposable for cutting this stuff to length/shape. You might be able to find a cheap pair somewhere or a buddy may have some too?
I am lucky enough to have a set of electric shears that are indisposable for cutting this stuff to length/shape. You might be able to find a cheap pair somewhere or a buddy may have some too? Thread Starter
Engine: 5.7
well...I went to class today...and raded our shed full of all types of metals....my instructor said it was fine for me to take any kind I wanted...so I took a ton of aluminum plate, at no charge....hard to beat that!
Royal_Z
Sep 30, 2015 08:45 PM
