How to make the ultimate power windows
Old Apr 15, 2004 | 11:19 AM
  #51
goofnrox's Avatar
I'm wondering how you wired in those transformers, since they don't work on DC, which is what is in your car.
Old Apr 15, 2004 | 11:34 AM
  #52
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Originally posted by MrDude_1
like i said in another post, i did it off the car on a powersupply...
read ya dingleberry.
if you're really ambitous, you'll find the other power window motor thread and find my post on exactly what i did. :lala:
Old Apr 22, 2004 | 09:18 PM
  #53
knhghs's Avatar
slow windows?
The 4th gen power window harness has an express-down module on it. Im using the 4th gen window harness and switches, with 3rd gen motors. It works great. One touch and the window goes down all by itself.
Old Apr 23, 2004 | 08:36 AM
  #54
goofnrox's Avatar
Selective comprehension strikes again. My bad.
Old Apr 24, 2004 | 11:40 PM
  #55
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
Originally posted by FastElectrics
Ok, I know it a bad word to use.. but is there any way to make a ford window motor work... those things are fast..
Yes they are. I had a 2002 F-150 for awhile and the windows were extremely fast.
However so are the ones in my 2003 Chevy truck. Your more likely going to be able to get something like that to work in our cars. That might be something to look into.
Old Jun 13, 2004 | 04:35 PM
  #56
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Any progress yet? I have 2 new doors and I would love to do anything to them before they go on!
Old Dec 13, 2004 | 10:42 AM
  #57
Faded's Avatar
Car: '91 Firebird
Anyone have any insight on the long term effects on the motors when putting more volts to them?
Old Dec 13, 2004 | 01:38 PM
  #58
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Far as I know they can overheat. Don't know if you would be using them long enough too though!
Using a junk door and a variable lab supply, I was able to get that door up mighty quick with 24vdc! It pulled some serious amps too, though I forget how many. Possibly just putting bigger power wires would help the stock setup?
Old Dec 13, 2004 | 09:42 PM
  #59
DTL504's Avatar
Car: 84 Z28 Convertible 2 Seater
Engine: Dart Little-M SBC 400
Transmission: Pro-built Automatics 700R4
Axle/Gears: Strange Engineering 3:73
I just bought 2 new window motors (OEM) from A1 Auto with the hope of getting my window problem solved.
We will see what happens when I get a chance to installed them when we get a warm front in Chicago.
Old Dec 13, 2004 | 09:44 PM
  #60
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
You having them put in, or are you going to do it? They use HUGE rivets! lol
Old Dec 13, 2004 | 09:50 PM
  #61
DTL504's Avatar
I will do the install myself....
As for the rivets I will substitute them for good ole Home Depot nut and bolts.
My only concern is how good is these OEM window motors from A1 Auto.
Also what is the best way/solvent to clean the window tracks thats full of old grease and dirt buildup?
Old Dec 14, 2004 | 07:54 AM
  #62
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
I went to use bolts and nuts, but ran into clearance issues... it was a long time ago though, and I don't remember why I couldn't do it!!
To clean the old guk out of the tracks I used a rag soaked with Dawn. Probably not the best way, but it works!
Old Dec 14, 2004 | 08:28 AM
  #63
DTL504's Avatar
What brand of Window Motor did you use? How does they function compared to a before and after?
Old Dec 14, 2004 | 10:46 AM
  #64
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Whatever Advanced Auto Parts stocks. They were like $24 each.
Worked the same as my tired old ones. It was the tracks and alignments that were out of wack.
Old Dec 14, 2004 | 12:05 PM
  #65
Faded's Avatar
Car: '91 Firebird
I cleaned all my tracks with some dish soap and a coarse sponge while the regular/motor assembly was out.
After I put it all back in I sprayed liberal amounts of Lithium grease on all 3 tracks.
I used the 1/4" rivets from GM. I guarantee you will have a very hard time trying to find a 1/4" rivet gun anywhere, though. I ordered one from Habor Freight. It was only $20 with shipping.
Speed wise it's the same as it was before the last motor completely quit working.
Old Nov 16, 2005 | 03:49 AM
  #66
89 tbi bird's Avatar
Car: 89 FireChicken
Engine: TBI
Originally posted by 87Formula356
... im having trouble with autoloc.com finding the parts i need.
Found the module at Autoloc
Old Mar 3, 2006 | 12:20 PM
  #67
Firebirdie92's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
Problem with the power windows
Yes the windows definitley suck due to many a things.
I have problems with both of my windows.
1. My driver side window will not go down unless some force is applied to it...I will go up if it catches in the right spot. I took off the door panel and checked it out, but it doesn't appear to be off track, i honestly don't have a clue!
2. My passenger side window rolls down ever so slowly, it does work, but it takes hellalongtime to roll up or down. Is it the relay or the motor?
Old Mar 4, 2006 | 09:46 PM
  #68
Firebat's Avatar
Re: Problem with the power windows
For #2, the motor is going out. Eventually it will move slower and slower and then it won't move at all.
I've only done one window motor so far (have to do 3 more). I used this thread as a reference - https://www.thirdgen.org/techbb2/sho...t=window+motor
and i used this pic as a template - https://www.thirdgen.org/techbb2/att...postid=1777631
Just have to make sure you print it out right. Made it really really easy to do.
Old Mar 5, 2006 | 02:10 AM
  #69
White93z34's Avatar
Car: 1987 Camaro IROC-Z
Engine: LB9
i seem to remember the power windows in my s/c running VERY slow from when i was far younger when the car was still quite new, and all these years later they still do....
Old Mar 5, 2006 | 03:11 AM
  #70
nedry's Avatar
Another thought: if window weight's a variable in the speed equation and you're comfortable with the idea, you might consider Lexan windows.
The problem is, if ya got anything of value in there, Lexan becomes a REAL bad idea due to security--easier to get through it than standard auto-glass. But if you're only driving a performance rig, don't have a good radio in it our leave valuables anywhere inside... (Paranthetically, you'll shave a little off gross weight, which should help performance a little if you look for other weight reduction options too...)
Just a couple shiny new Lincolns.
For the guy who wanted self-stowing T-tops: Been watching a little too much Knight Rider again, have we? lol
Old Mar 5, 2006 | 04:38 AM
  #71
2kflhr's Avatar
Car: '68 396 SS/RS, '02 SS
What if you installed a relay at the switch? Wouldn't that supply additional current.
Old Mar 6, 2006 | 10:35 AM
  #72
MrDude_1's Avatar
Car: 91 Camaro Vert
i made a small prototype thing to mess with.. basicly having a microcontroller pulse out a signal.. two inversed pulse signals makes a nice square wave i can feed a transformer... then rectify... a kind of DC-DC stepup powersupply if you will..
id need to make it cheaper (not a problem) but i was thinking if i fed 18v to my window motors, they'd go faster without much life loss...
i probly wont follow thru with the idea, but its something to play with.
Old Mar 6, 2006 | 10:36 AM
  #73
MrDude_1's Avatar
Car: 91 Camaro Vert
i started on it after reading this and some other similar pages:
http://murray.newcastle.edu.au/users...92/doubler.htm
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
stalkier
Aug 13, 2015 12:59 PM
