Poly Bumper Question
Old Feb 21, 2004 | 11:07 PM
FstBrd6point3's Avatar
I have a complete set of Trans am ground effects and I want to know the easiest way to get the paint off... do I have to sand and sand until I get somewhere, or are there strippers made especialy for eurethane I might be able to pick up? If I do have to sand it all off, what is the best and easiest way to do it? grit recomendations? do I have to go ALL the way to the yellow eurethane, or is it ok to just sand some of the old paint of and prime them? I dont want to do a half *** job though
Old Feb 21, 2004 | 11:12 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
You need to get rid of any cracking paint. They make some stuff i beleive its called rubber bumper striper at most parts stores, it doesn't always work as good though. You want to stay away from agressive grits on the urathane, not sure what girt to recommend though.
Old Feb 22, 2004 | 01:42 AM
Prolly stick with like a 400 grit, right? also, the bumper cover has a small crack in it the corner of one of the fog lights... I think I saw someone mention something like a bumper repair kit? or could I use bondo? I can see bondo on a flexible part like that becoming a real pain in the *** tho. anyway, thanks for the help.
PS... might have that center brake light housing you are looking for.... I will have to look through my basement tomorow, but I am almost positive I have one.
Old Feb 22, 2004 | 09:06 AM
Rage13's Avatar
Car: 89 Firebird
don't use bondo, it'll chip off and crack if the bumper flexes. 400 grit paper will get gumed up to fast to get any real work done. strippers are a mess and i've not found one that don't eat the poly. also after you have it all saned down make sure theres no cracks in the poly, other wise the paint will crack right where the poly did..
i've been using a DA sander with 180 grip paper, and going all the way down. just have to make sure you keep moving around or you may burn a spot on your poly bumber. i've been able to get most of it with the DA, but some places are just to tight and have to get them by hand.
Old Feb 22, 2004 | 10:28 AM
ok thanks for the help guys... I guess I will just use my sander to do most of it.
Old Feb 22, 2004 | 04:37 PM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
The urethante/bumper paint stripper is pretty much useless unless your bumper was painted with water colors. That stuff barely softened up the paint on the new bumper. Im gonna take a DA sander to it carefully.
Old Feb 22, 2004 | 05:55 PM
nolanr0413's Avatar
Car: Trans am
what about buying a new bumper from gm .
Old Feb 22, 2004 | 08:05 PM
dont really wanna spend the money to be honest... besides the small crack in the foglight area, the bumper is perfect, it still have the perfect shape and lined up great with the body... I basically got it for free too
Old Feb 23, 2004 | 08:09 AM
FyreLance's Avatar
Car: 00 TA, 91 Formula, 89 RS
I second the 180 grit.
Old Feb 23, 2004 | 08:23 AM
thans for all the help guys... I'll post some before and after pics eventualy to show how everything come out, thanks again
Frozer!!!
Jan 19, 2024 04:55 PM
chazman
Aug 28, 2018 03:25 PM
mikey8494
Aug 22, 2015 07:57 PM
chazman
Aug 22, 2015 02:01 PM
redmaroz
Aug 16, 2015 11:40 PM
