Need help with back seats
Old Feb 28, 2004 | 11:41 AM
Formula4Speed's Avatar
Car: 1990 Formula
Engine: 305 TBI (LO3)
Transmission: 5 speed manual
I can't get the torx bolts off the black piece that guides the seatbelt...I've tried WD-40 to loosen them but they won't budge at all. Is there any other way to remove the back seat without taking these things off??? I really want to get my 4th gen seats in.
Old Feb 28, 2004 | 02:23 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
For some reason they have loc-tite on them. I ended up breaking one of the screws off when I did it, but the 4th gens had the brackets on them. You will need a socket style torx bit. Normally I would of just heat the screw and the heat will release the loc-tite, but I was afraid of setting the seat on fire.
Loosen it a turn back it up a half, repeat is what I did, but like I said I broke one of the screws doing it.
Old Feb 28, 2004 | 02:43 PM
Car: 1990 Formula
Lock-tight? Is that whatever the blue stuff on there is? I got both off of one side now with a lot of dedication...like an hour per bolt. Maybe I'll drive down to the store and buy some rachet style torx.
Old Feb 28, 2004 | 03:03 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
yep the blue stuff, I don't know why either its not like they are likely to vibrate lose or anything, but leave it up to gm. Oh yea I broke 2 torx bits that I had already had also, lol finally went to sears and bout a crafsman one :-)
Old Feb 28, 2004 | 04:10 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
use alcohol, pour alcohol in the tread arae it will loosen up the locktight, give it some time to do its thing but it will remove the lock tight.
defitanly need a socket style torx no way your gonna get it with a screw driver.
Jeff
Old Feb 28, 2004 | 04:33 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
You dont have to take those off to remove the backseats.
You remove the seat belt retractors in the hatch under the plastic paneling and abracadabra... the whole thing comes out, seat belt guide, retractor and backseat all at once.
Old Feb 28, 2004 | 04:53 PM
Car: 1990 Formula
Well I went and got the torx set for my ratchet and man was that easier. As for the screwdriver I got 2 out with it and the second 2 with the ratchet set...its a good thing you guys are around or I would never get anything done right :hail:
Vintageracer
Jan 10, 2020 05:33 PM
Fast355
Dec 2, 2016 06:33 PM
lee01
Apr 9, 2016 01:56 PM
Wylecoyote08
Nov 6, 2015 03:46 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
