Cannot Open Hood
Old Mar 3, 2004 | 04:09 PM
AndrewDoK's Avatar
Car: 1992 Camaro RS
Engine: 5.0l TBI
Transmission: Automatic
Cannot Open Hood
Last week my car started leaking antifreeze. So I parked it and tried to open my hood to check it out. The hood release didnt work at all, as if the cable was not even connected. After I checked I found out the cable was totally disconnected from the hood release. I have had a few people come and try to open it to no avail. I tried pushing it down and hitting it. I have tried pulling it up from both sides. I even had my friend who is a locksmith come and try to open it.
So I deicided to get under the car and try to release it from there, but nothing works.
If anyone has any idea how to get it open please help me.
Old Mar 3, 2004 | 04:39 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
only thing i could think of is take it to a mechanics shop or the dealership someone might know how to pop it
Old Mar 4, 2004 | 04:44 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
You can take the air dam off the bottom of the car and unbolt the latch from the bottom, its a huge headache though.
Old Mar 4, 2004 | 05:12 PM
Daishi's Avatar
Car: 1988 Camaro IROC
Axle/Gears: 3.27 9 bolt posi (non 1le)
if ur lucky its just the spring, in which case, get a buddy to pull the hood lever out, and hold it there, and u pull up on the hood
Old Mar 6, 2004 | 09:28 AM
tagta189's Avatar
If when you initially pulled on the hood release it felt like it pulled the mechanism like it was supposed to but then nothing after that then it has released the latch but your hood is sticking a little bit.Try driving it around the block at slow speeds a few times or even on a bumpy road and it will usually pop loose after a short time.Mine does this now and then.just don't go too fast though.
Old Mar 6, 2004 | 09:36 AM
white91formula's Avatar
Car: 91 formula
Transmission: t5
i had this problem when i first got my car, and it needed oil badly !!! what i had to do was crawl under the car wtih a stocket (1/2 inch i belive) and unbolt the latch from the hood so it would pop up on its own and not be connected to anything.
Old Mar 7, 2004 | 12:24 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Mine would occasionally get stuck last summer. Try this:
Have someone pull out the hood release and hold it out. You grab the hood at thr front, like in the headlight opening, pull up firmly, and give the hood a good smack with the other hand right above the latch. Never failed for me.
Hotrodboba400
Dec 10, 2019 07:07 PM
neilb
Sep 15, 2015 05:06 PM
luvofjah
Sep 3, 2015 07:08 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
SlowAZ28
Sep 2, 2015 05:19 AM
