Door Hinge Kit
Old Mar 5, 2004 | 08:55 AM
DTL504's Avatar
Car: 84 Z28 Convertible 2 Seater
Engine: Dart Little-M SBC 400
Transmission: Pro-built Automatics 700R4
Axle/Gears: Strange Engineering 3:73
Door Hinge Kit
Is there a good kit in the market that compare to the kit that Andy sells that will do the job. I need to fix my dooors before I can get the car painted and looking to save some money. He sell the for $97.00 each and I will need two $194 plus shipping.
Old Mar 5, 2004 | 07:01 PM
Charged350's Avatar
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
75 bucks or even less to have it fixed by a body shop, cheaper then the kit and no work for you, well look at that
Old Mar 5, 2004 | 09:04 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
I'm really curious what the auto body shop is replacing for just $75 as you claim. I suspect it has to be just the lower hinge pin and lower hinge bushings. If the lower hinge pins and bushings are all you need to replace you can do that yourself for a lot less than the $75. That includes buying the GM door spring removal tool.
And in answer to the original question, no other kit exists that will do what 3rdGenSolutions kit (aka Andy Z28) does. The kit on eBay from Canada consists of just replacement upper hinge pins and nuts, no new upper hinge bushings. GM's solution is more expensive yet, requiring you to drill out the existing spotwelds, un-wire the door electricals, lay the door on the ground, drill and bolt a new hinge in place then re-hang the door. Roughly double the labor to do that vs. 3rdGenSolutions kit.
The standard kit (non-greaseable) is $74 per door, not $94. The Greasable upper hinge repair kit is $96 per door. I am the only distributer of the kit that adds a grease fitting cap on the zerk fittings. It just helps to keep them free of debris between greasing them.
Lon Salgren
Top-Down Solutions
Old Mar 5, 2004 | 09:10 PM
DTL504's Avatar
Lon
Thats what I was trying to find out in a cosyt comparison. I doubt that a body shop will fix the hinge for less than $75.00. Thats what they charge an hour for labor. I will be getting back with you.
David
Old Mar 6, 2004 | 08:31 PM
Charged350's Avatar
Car: 87 IROC Z28
Well really now, not only did i just do a set of doors the other day on a merc, i work at a shop so i know this ****, no doubt that your kit will fiix it, but then who will align it again, its not science but its not that easy to get a door to close under its own weight when let go, thats just my test when i do doors, but yeah, lower adn upper hinges fixed for 75 bucks a door man, and we all know that the bottom hinge is the one that always goes bad, the top one aint all that abused....
Old Mar 7, 2004 | 01:02 AM
lonsal's Avatar
Originally posted by Charged350
...but then who will align it again, its not science but its not that easy to get a door to close under its own weight when let go, thats just my test when i do doors...
You're right, it's not "Rocket Science" to re-align a door. I sell the E-Z Store Door alignment tool by Steck which is designed for just this purpose. Anyone can easily align the door themselves if necessary after repairing the door hinge if they have the proper tool. I only wish I'd known about the tool before I invested in MAC Tools version which is not only a lot more expensive, but a pain to store by comparison.
Lon Salgren
Top-Down Solutions
Old Mar 7, 2004 | 01:12 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Here's an easy way to line up your doors. Open the door a little bit, and then set a floor jack under it to support it. Put a towel or something between the door and jack so you dont scratch the paint. Now loosen the hinge bolts, move the door where you think it needs to be. Use the jack to raise/lower the back part of the door, and roll it back/forth to adjsut forward/back. Now tighten the hinges back and close the door. You will probably have do do this a couple times to get it right, but it works, and doesnt require any special tools.
Old Mar 9, 2004 | 03:22 PM
dennisk's Avatar
Car: Chevy truck,
Engine: 5.3
Transmission: auto
After all that! Where do i find the parts
Cheap Trans am owner here!!!! i need Just the drivers Lower hinge rebuilt/replaced. WHAT ever needs done. it needs to happen. IDEAs? I can buy whole sale from my Chevy and Pontiac dealers. Or is there any body else makes the kits? Need Web addresses or Phone numbers. Thanks
Old Mar 9, 2004 | 03:25 PM
lonsal's Avatar
Just click on my TDS logo above. Lower hinge pin and bushings and the GM spring removal tool are in stock.
Lon
1992 Trans Am
May 10, 2023 07:19 PM
86IROC112
Apr 9, 2016 10:20 PM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:14 PM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
