4th gen seat question... (not a "will it fit" ?)
Old Mar 12, 2004 | 06:24 PM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
I have a set of '96 SS Leather seats in my 87 IROC. One thing has bothered me since I put them in. The passenger side seat is WAY to far forward, even all the way back. It looks funny its so far forward.
Do all the 4th gen seats do that or is it just mine? Is there a "fix" for it?
Old Mar 12, 2004 | 06:38 PM
Steve86TA's Avatar
Car: To many to list
Are you sure there is nothing in the track blocking it from going back farther?
Old Mar 12, 2004 | 10:01 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Mine out of a 97 goes pretty far back, not sure if it goes as far as the drivers or not though.
Put the track off your 3ed gen seat on the 4th gen seat and that should solve the problem if its the track.
Old Mar 12, 2004 | 11:57 PM
jcurrieirocz's Avatar
Car: '81 Trans Am
Engine: 6.6L
Transmission: auto 350
it will you just must have a stuck track......you dont have one power seat and a manual seat do yah?? that would explain it.
Old Mar 13, 2004 | 10:41 AM
Dante93GTZ's Avatar
Axle/Gears: 3.23:1
My drivers side is a full 6-way power and the pass is a manual. But I mean, GEEZ, the pass seat almost touches the 98+ cupholder when its pulled out.
Anyone else have this? I mean I look at the pass seat and cringe its so bad! I'm only 6'2" so its not like I am a giant that needs the D/S seat all the way back either.
Old Mar 13, 2004 | 10:49 AM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
The seat can still move back an inch or so from where it is in the picture.
Sounds like the track is stuck or something, like I said the seat will fit on the the thirgen rail so use you old rail on the pass seat.
Old Mar 13, 2004 | 10:55 AM
Dante93GTZ's Avatar
Axle/Gears: 3.23:1
After work today I'm gonna probably take the seat out and check it. If worse comes to worse and I do have to use my old 3rdgen tracks, is there any drawback to doing so? Are they the same tracks or will one seat sit higher than the other?
Just covering all bases here. Thanks for the help guys. I'm gonna see if I can get a digital camera to take a pic so you guys can see the seats too.
Old Mar 13, 2004 | 12:01 PM
Dante93GTZ's Avatar
Axle/Gears: 3.23:1
Just went and checked the car at break. Looks like your seat is a good 3 inches farther back than mine
Old Mar 13, 2004 | 12:11 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
not positive if there is any height difference in the brackets but I don't think there is. Check the bracket I've had change get in the track etc.
Old Mar 13, 2004 | 01:53 PM
NEEDforSPEED's Avatar
i dunno if this is the same prob i had... but i couldn't get the passenger side holes to line up with the bolts ... so i just put the track on the back bolts and pushed the lever to moved the track forward "the thing for your seat to move back and forth" and i got all of the bolts to line up with the holes...
Old Mar 14, 2004 | 07:03 PM
Dante93GTZ's Avatar
Axle/Gears: 3.23:1
Turns out, the track was blocked with something. Its fixed and really nice.
Thansk guys.
Frozer!!!
Jan 19, 2024 04:55 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
cam-mike
Aug 24, 2015 07:23 AM
