Painting Interior Trim
Old Mar 16, 2004 | 04:41 AM
gholian's Avatar
Car: 82 Pontiac Firebird s/e
Engine: 2.8 V6
Transmission: TH200C
I decided to paint the plastic trim panel under the deck lid. I used a special Plastics primer from a company called SEM as the plastic is polypropalene. I sprayed it with a spray can and it came out crap so I want to redo it with a spray gun. I have never done this before so the questions I have are, in order to repray it do I have to sand it down to the plastic and re prime it or is it enough to give the panel a slight sanding and repaint. Will new paint stick okay to the old paint or without using a primer again will it crack?
Thanks.
Old Mar 16, 2004 | 07:23 AM
crnsuperduty's Avatar
Car: 88 sc. convert
Engine: 305 TBI
Transmission: Formerly 700-Now T5
I never painted plastic like that, but from my painting experience if you have 1 bad coat of paint, it won't ever come out right. You are always better off sanding old paint off and starting over.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
lee01
Apr 9, 2016 01:56 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
