Pouchy golvebox thingy
Car: 1988 Pontiac Trans Am
Engine: 5.0L Fuel Injection
Transmission: Automatic 4speed /w OVerdrive
Hey I was wondering if that pouchy gloveboxy thign can be removed. Whats holding it there and how hard would it be to...remove.
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Transmission: 4 Spd Auto
I think its just stuck on there. When I parted out my trans am I just pulled it off but I will go outside and have a look at the back of the pouch to make sure tommorow.
if anyone already removed theirs then can I get a pic of what the backside of it looks like?
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Heres the pic of mine. One of the tabs is missing but as you can see on the rest of them they kinda look like screws but just pop in and out of the holes in the dash behind the pouch.
All you have to do is pull it off.
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
map pocket: thirdgen for glove box. lol. It should be easy to remove. Just try to wedge under it and "fork" it by prying on each side of the clip. if you want to reuse it just go slowly so the tab doesn't get damaged. They're similar to the clips on the door panel if you've ever removed one.
