open element guys
Old Oct 7, 2001 | 05:16 PM
Sleipnir's Avatar
open element guys
ok, on the snorkel to the stock crap, the thermac device thingy that has a hose onto the exhaust manifold, when you took that junk off, did you close the hole? do you need to? what did you close it with is so?
also i was looking in my hanes manual thingy, and it explains the thermac thingy to let the hot air in so you get better cold engine performance, is that so? does it run irregularly with this detached??
thanks in advance
Old Oct 7, 2001 | 05:23 PM
Neo's Avatar
Neo
My hole is open. No sick comments! I have nothing to close it with
Old Oct 7, 2001 | 05:28 PM
Tas's Avatar
Tas
the heat riser just transefers heat not exaust. There is nothing but heat coming out the hole. with open element you just need to cap the line on the front of the TBI and move the sensor on the housing to a cool place.
-Tas
'89 Formula WS-6
305, TBI, 700R4, P.A.W. 14x3 open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips, Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248)
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
Got Beach?
Old Oct 7, 2001 | 05:29 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
if you are talking about the sleeve that goes around the manifold...just cut it up and rip it off. its worthless and looks like a$$ after you get an open air cleaner.
-Brian
1991 Camaro RS - ultra blue metallic, t-tops
GMPP 350 HO crate engine - 454 TBI, MSD ignition, SLP exhaust, everything is new
700R4 - 2,400 stall converter, vette servo, shift kit
z28boy.cz28.com
Central New York F-Body Association
z28boy@twcny.rr.com AIM - "Z28 Boy"
Daily driver - <A HREF="http://members.fbody.com/z28boy/grandprix" TARGET=_blank>
1998 Pontiac Grand Prix GT</A> - 2 door, black
Old Oct 7, 2001 | 10:24 PM
PopaPork's Avatar
One way around haveing that stupid hole in the manifolds.......Get headers. They dont have it
Old Oct 7, 2001 | 10:25 PM
Tas's Avatar
Tas
ya but some of us need to keep it come test time
Old Oct 8, 2001 | 05:26 AM
Sleipnir's Avatar
yeah exactly tas =) i cant afford headers after i put out like 135 dollars for the cheatest cat back i have seen! esp after i put that with an open element. thanks guys, so i can just leave it open, and what did you cut up and take off?
Old Oct 8, 2001 | 03:16 PM
z28camaro396's Avatar
I bought a k&n air filter for my stock air cleaner, will that filter fit well under a 14x3 open air element. Also, what to do about the small black metal hose on the passenger side that hooks up to the stock air cleaner.
1988 305 TBI camaro. Flowmaster exhaust, K&N air filter, complete IROC-Z makeover (stripes, ground effects, interior...etc), Kenwood c.d. player, Sony Xplod 6x9's, Blaupunkt 3 1/2's.
Old Oct 8, 2001 | 03:24 PM
Sleipnir's Avatar
take it off, its only 3 bolts, just take it off and use it for halloween decorations
Old Oct 8, 2001 | 03:43 PM
Tas's Avatar
Tas
<font face="Verdana, Arial" size="2">what to do about the small black metal hose on the passenger side that hooks up to the stock air cleaner.</font>
get a push in breater for the valve cover. $3
Old Oct 9, 2001 | 10:14 AM
NTChrist's Avatar
<font face="Verdana, Arial" size="2">Originally posted by z28camaro396:
</font>
No, dammit. I looked for a 12" open element housing for the longest time, hoping to use the stock element in it. I had JUST bought the d@mn K&N before I started frequenting this board, and everybody that's anybody has one here.
On a lighter note, anybody wanna buy a K&N?
No guts, no glory.
Old Oct 9, 2001 | 12:55 PM
Am I correct that leaving the breather (small black hose with filter coming from the passenger's side valve cover, in my previous juvenile remark) is harmless as well as removing it completely and/or getting an aftermarket filter to plug it? Also, in regards to the coil wires-is that the wires in the TBI or under it or what exactly. Sorry for the lack of knowledge questions-just don't want to screw up the ride. Thanx.
Old Oct 9, 2001 | 12:56 PM
Old Oct 9, 2001 | 02:44 PM
NTChrist's Avatar
Also, in regards to the coil wires-is that the wires in the TBI or under it or what exactly. Sorry for the lack of knowledge questions-just don't want to screw up the ride. Thanx.</font>
The coil wire (singular) shouldn't be a concern when changing to an open element. Just make sure it doesn't rub on the housing.
It goes from a little black box-shaped thing BEHIND the tb, to the middle of the cap on your distributor. It has nothing to do with the induction system, and everything to do with the ignition system.
No guts, no glory.
Old Oct 9, 2001 | 05:35 PM
HrdRockA4305's Avatar
Watch out for rubbing the coil wire! It appearantly was and I didn't know it until *ZAP* about 2 weeks ago it finally wore through the insulation.... left a small black mark on the air cleaner where it burned the chrome off... black marks around where it grounded through the TBI... and some wire blew into 2 pieces and killed the car, had to be towed. Couldn't tell that the wire fried until we got under the car on a lift. For the time being, i notched the metal around the coil so it won't come in contact at all, just with the rubber on the filter, and i'm putting a 10 or 12" OE on this weekend cause It'll be one less thing to worry about happening again.
88 Camaro (The mighty LO3 SC!)
305TBI/700R4/2.73/123,XXX miles
14" Open Element and Flowmaster 80 seires
Next up: headers and gears
Old Oct 10, 2001 | 09:51 AM
NTChrist's Avatar
OR, you could replace the coil with something a little more exotic.
I bought an accel coil, which is meant to be mounted on the firewall. Because of the positioning, I don't worry about it rubbing on the open element. It also looks a little cleaner, what with the coil in plain view, and the 8.8 coil wire.
No guts, no glory.
Old Oct 10, 2001 | 02:39 PM
GKK's Avatar
GKK
Car: 91 Camaro RS Update: Sold Camaro, now own a "91" Corvette.
Engine: Corvette L98 TPI
All I did was loosen up the two bolts that hold the coil bracket assembly and pivot the left side of the bracket back towards the firewall.( the left side of the bracket as you're standing in front of the car). Then just tighten everything down. Now there should be about 1/16"-1/8" clearance between the wire connector and air cleaner base.
[This message has been edited by GKK (edited October 10, 2001).]
Old Oct 11, 2001 | 12:17 AM
GiddyUP305's Avatar
Engine: turbocharged 4 cyl Dohc
Transmission: 5 spd sentronic
the install of the open element is simple , a two minute job i haven't had a problems with the coil hitting it, it has a 9/16 drop on it and clears the coil and the hood... i think it complements the Stb and makes the engine compartment look better.....
1991 ASC firebird convertible
-305 V8 tbi
-700-r4 W/ slp shift kit
-k&n open element
-Cherrybomb exhaust
-HP motorsports STB
-McEwen white face guages
-Alpine sound
-Ground zero springs
-KYB shocks/struts
-16" diamond spoke wheels
-245-50-16 Gforce tires
Old Oct 14, 2001 | 01:13 AM
MightyMouse's Avatar
Car: 90 RS
Engine: 383
Axle/Gears: 3:23
If your coil is in the way just take off the bracket and let it wander about the top of the intake (coils are nomadic by nature and they work better when not in captivity) this is what I did.
Old Oct 18, 2001 | 01:06 AM
91RS5.7TBI's Avatar
WHAT?!?
Old Oct 18, 2001 | 06:24 PM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
nomads?? um, ok.
guys, just BEND the bracket!!! it will drop the coil back AND away from your aircleaner.
at worst it will burn you car to the ground.
in my case it just fried every fusable link i could find, so. read the RED on the tech article and bend it.
read the article. if you have a ? after reading it twice email me. this kindof clutters the boards a bit.
Jae992
Aug 27, 2015 09:07 AM
Street Lethal
Aug 14, 2015 08:25 PM
wruiz
Aug 13, 2015 09:07 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
