the infamous 85 to 145 speedo question
Old Mar 20, 2004 | 07:41 AM
F-Bobby's Avatar
Car: 1989 Formula 350
Engine: Stealth Rammed 350
Axle/Gears: 3.45 9 bolt
hey guys, i did a serch and found out that the clusters are a direct swap, but i got kinda confused cause some peopel were sayign that the 85 MPH is mechanical and the 145 is electric and other peoepl were sayign they are the same. i wanna knwo whihc is correct. if it is a direct swap i'll get it dont next weekend most likely. but if it requires wireing ill have to give it to my buddy to do.
P.S. i have an 87 Firebird.
Old Mar 20, 2004 | 08:44 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Don't know when they switched to electric but through 89 all were cable that I've seen.
Old Mar 20, 2004 | 09:30 PM
Matto'85TA's Avatar
Car: 2001 Trans Am WS.6, 1985 Trans Am-RIP :,(
Engine: LS1, 305 TPI
Transmission: 4L60E, 700R-4
Camaro speedos switched from mechanical to electric in 91 i think. Firebirds switched in '86. I know that for sure cause my '85 is cable driven, and my 86 is electric.
Old Mar 20, 2004 | 09:41 PM
ES87iroc's Avatar
Car: 1987 Camaro Z28 IROC-Z
Engine: 5.7L TPI
Axle/Gears: 3.42:1
Firebird speedometers:
Cable drive 82-85
electronic drive 86-92
Camaro speedometers:
Cable drive 82-89
electronic drive 90-92
These are the facts, hope this clears up the question!
Old Mar 21, 2004 | 10:01 PM
GarageToys's Avatar
Car: 89 Iroc Hardtop
Engine: LB9 w/G92 Pkg
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt, 3.45
Cable drive 82-85
Cable drive 82-89
What about the differences between "guage" cars and "idiot light" cars??? I believe that made a difference in which type speedo you got as well.
Old Mar 21, 2004 | 10:20 PM
Matto'85TA's Avatar
By "idiot light" do you mean digital dashes? Not sure what you mean. I'm pretty sure the digital dash cars use electronic speedos.
Old Mar 22, 2004 | 06:11 AM
ES87iroc's Avatar
Engine: 5.7L TPI
Axle/Gears: 3.42:1
The speedometer units themselves were the same, however I am not 100% sure wether the senders were different for the idiot lights vs. guages. (open/short vs. a variable feed)
Old Mar 22, 2004 | 06:27 AM
Screamin'87GTA's Avatar
Car: Trans Am GTA
Transmission: Rebuilt 700r4 with stage 3
My friend has an 84' bird with the "idiot lights" we tried to swap in a full gauge cluster both with mechanical speedos and no luck..
but thats going from lights to gauges.
Old Mar 22, 2004 | 06:55 AM
ES87iroc's Avatar
Engine: 5.7L TPI
Axle/Gears: 3.42:1
Right, the wiring is the same, but you may have to change the senders.
Old Mar 22, 2004 | 06:59 AM
Car: Trans Am GTA
I looked at the pin configuration, some of the pins arent used for both clusters.... there are more pins in the new cluster then there are in the old cluster... none of the gauges worked.
Old Mar 22, 2004 | 11:41 AM
Diabolical's Avatar
Car: 85 Trans Am WS6
Engine: 305HO L69
with idiot lights, rather than having a gauge that tells you what the water temperature is, there's just a light that goes on when you reach the danger point. i believe they had those for water temp, oil pressure, not sure if fuel level and voltage were idiot lights or not, i've never actually seen a car with them.
Old Mar 22, 2004 | 12:19 PM
ES87iroc's Avatar
Engine: 5.7L TPI
Axle/Gears: 3.42:1
Hmm, that's odd. Perhaps it's a firebird thing? The camaro's just used a open/short switch vs. a variable sender for the gauge vs. lamp.
Old Mar 23, 2004 | 10:37 PM
F-Bobby's Avatar
yeha i have all the guages. temp, volts, oil pressure, etc. but still only the 85 mph speedo. can't figure that one out. thanx for all the info guys.
Old May 26, 2007 | 12:40 PM
jyoung86's Avatar
Car: 1987 Trans Am
Engine: zz4 350
Axle/Gears: 2:73
Re: the infamous 85 to 145 speedo question
I have an 87 trans am with an 85 mph speedo. From what i've read in 86 pontiac started useing electronic speedo's instead of cable driven. I'm just double checking but does anyone know if pontiac had an electronic 85mph speedo in 1987?
Old May 26, 2007 | 12:55 PM
RocsRose86's Avatar
Car: 1986 Irocz28/04 GMC Yukon
Engine: Ram Jet 350(*TPI*)
Transmission: Turbo 400 w/1500 stall
My 86 Irocz has 145mph speedo. also has temp ,volts ,oil press,rpm . It also has some blue cirlce light that i have no clue what its for. and it stays blue any ideas?
Old May 27, 2007 | 01:46 PM
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
Axle/Gears: Dana44 4.10
Cars with the "idiot lights" still had mechanical speedometers
Old May 27, 2007 | 07:51 PM
chevymad's Avatar
Car: 87 Formula
Engine: 327
My 87 formula had the 85mph electronic speedo. When I put the indiglo overlays in they only made them for the 120mph speedo. So I swapped in a 120mph unit. Direct swap.
Old May 27, 2007 | 11:10 PM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
high beams??
Old Jun 1, 2007 | 09:09 AM
xbcrguy182x's Avatar
My 86 firebird has a mechanical speedo with dummy lights. In order for me to use a Gauge cluster, I would have to get one from a 86-92 and get rid of the cable and use the VSS, and somehow wire it to the ECM. The clusters from 82-85 with gauges are cable driven, however,m different wiring from my 86. Once installed the fuse would blow and nothing would work. So I just gave up and stuck with my dummy cluster. If you look on the connector of a 82-85 cluster, theres one fat gold pin. From 86-92. theres no fat pin. My 86 connector on the firewall has no fat connector. Therefore, i am stuck with my dummy cluster unless I swap out the speedo cable with a electronic system(VSS). Thats my nightmare...hhahah
Old Jun 1, 2007 | 12:32 PM
RocsRose86's Avatar
Originally Posted by 91 camaro racer
high beams??
yeah i hooked up the bulbs backwards so my high beams stayed on thanks!
Eric2ndGen
Nov 5, 2015 01:51 PM
stickychinsac
Aug 31, 2015 06:06 AM
IROCZDAVE (88-L98)
Aug 24, 2015 06:54 AM
redmaroz
Aug 16, 2015 11:40 PM
Irocohio
Aug 12, 2015 08:03 AM
