fusable link in front signals?
Old Mar 21, 2004 | 08:42 PM
Blake's Avatar
Car: 1991 Camaro RS
Engine: 406ci
Transmission: T-56 LT1
is there a fusable link for the front signals? if so where abouts is it located? trying to wiring in a set of blue AND orange front signals on a switch
thanks
Blake
Old Mar 22, 2004 | 06:02 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Fog lights wire through fuse link, turn signals are just fused in the fuse box.
Old Mar 22, 2004 | 08:27 PM
d_johnsen's Avatar
Car: 1989 Firebird
Axle/Gears: ?
mr blake, in my quest to find a solution for you, i have found one that should work, what u need to get is a 4pdt relay, 4 POLE DUAL THROW 12dc relay
Old Mar 22, 2004 | 08:38 PM
Blake's Avatar
Car: 1991 Camaro RS
Engine: 406ci
lol do you have any idea where I can get that? I tried looking but couldnt find any. but now like I said, I'm not getting any signal flash in the front lights, so maybe how I had it set up worked but its getting no flash power, the passanger side high beam wire is baby blue at the socket, but is then turned into a white wire. so I traced it back, hopefully, to the firewall where all the wires go to, and cut it there, and then ran a wire from the postive side of battery and touched the end of the spliced wire, and it did not blink....? thats why I was wondering if it was a fuseable link. but I hooked everythign up correctly becaue I unhooked those added lights, and still no signal. just running lights....?
cheers
blake
:lala:
Old Mar 22, 2004 | 08:40 PM
d_johnsen's Avatar
Car: 1989 Firebird
Axle/Gears: ?
that might have to be ordered online, i would check canadian tire, ask them if u can find it in the relay section, they might have it hidden, and ill help you wire it up, the only thing is, when a relay is in use, it uses power, that wouldnt be a problem as long as your car is running, and would be fine for a period of time with the car off, let me know
69 Six Pack
Oct 5, 2015 07:51 PM
LittleFranks
Sep 17, 2015 12:22 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
