Can I fix my Trip Odometer?
Old Mar 31, 2004 | 04:30 PM
Damien00677's Avatar
Car: 2006 'Nox 91 Camaro RS 91 1500 Silv
Engine: GM 3.8L, 305 SBC, 350 SBC
Transmission: Auto, auto, auto
The highest it can count is .9 mi. So that gets a little annoying. Is there any way to fix it? Also, there is a ticking noise that I can hear some mornings that seems like it might be related.
Old Apr 5, 2004 | 02:30 AM
DanRS's Avatar
Car: 89 Camaro RS
Engine: LO3 305 TBI
Transmission: T5WC
I also have a problem with my trip odometer. I reset it and a few moments later, I have gone something like 450 miles and then it stops turning at all.
Old Apr 5, 2004 | 08:02 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
One word --NO. Just join the club with non working trip odometer's.
Old Apr 5, 2004 | 10:16 AM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
IROCZDAVE sells repaired units, I dunno what he does, but he sells the speedo by itself, and hes several of em with varying mileage readings. Might be worth it if its really something that you wanna replace. I think I will just go looking for a low miles cluster and swap it out. Mine is the same way, and it pops like every couple seconds on the freeway, at night its damn annoying
Will
Old Apr 5, 2004 | 08:54 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Actually you can if your careful,but you have to partially take it apart.It helps if you have a good trip Od to replace it.Ive done 2 in the past.
Old Apr 5, 2004 | 11:50 PM
DanRS's Avatar
Car: 89 Camaro RS
Engine: LO3 305 TBI
Transmission: T5WC
...Got any pics of the inside of the speedo, by any chance?
Old Apr 6, 2004 | 12:15 AM
2.73's Suck's Avatar
Car: 1985 Mustang GT
Engine: hamsters
Transmission: a hamster wheel
thats exactly what mine does, same miles and all
Old Apr 6, 2004 | 07:36 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
I dont have an extra speedo anymore to take pics of,But there not a whole lot to it.The trip Odometer is a seperate peice from the rest of the speedo.There are 2 plastic tabs(part of the speedo housing) that retain the trip Od in place.One of them might have broken off.best thing to do is remove it to see whats wrong or maybe get a replacement from the junkyard(or for parts).
Old Apr 8, 2004 | 12:07 AM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
I had that happen to my Z way back when; I 'repaired' it by wrapping a piece of single-strand wire (22 gauge or so) around the 'axle' and then tying it to something on the back of the speedo head to hold it in place. I prolly got another 100k miles out of it with no problems, and it would likely still be going, if the car still was.
Old Apr 8, 2004 | 07:47 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Spent a half day fixing mine as described above. Used a piece of small wire and just tied up the axle. Works fine and resets ok too. Real shabby deal with the skinny little tangs holding all this together. Hard to describe, have to take it apart and see it.
92firebirdguy
Sep 1, 2016 07:53 AM
PestilenceIV
Sep 22, 2015 07:39 PM
BWilcox
Sep 20, 2015 12:19 PM
formula1LE
Sep 12, 2015 08:31 PM
andy74
Sep 3, 2015 08:41 AM
