Anyone ever replace a battery tray?
Old Mar 31, 2004 | 05:44 PM
Notplayn's Avatar
Car: Depends on the day!
Engine: the kind that runs on money
Transmission: One that holds up, I hope
I think I need to replace my battery tray. It looks to be spot welded in (cant really tell). Does anyone have any recommendations on removing it? Is there an aftermarket one available? I maybe able to repair this one but I just don't know at this time. Thanks
Old Apr 5, 2004 | 09:02 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Classic sells an G.M. replacement.$20 or around there.They are spot welded in BTW.
Old Apr 6, 2004 | 07:45 AM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Mine is riddled with rust and needs to come out as well before the cancer spreads. Can you elaborate on "Classic"?? Is there a website...or a publication...part #'s??? Also is the tray they offer a reproduction part that will fit the same way? or will I have to modify. Thanks.
Justin
Old Apr 6, 2004 | 09:13 AM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
http://www.classicindustries.com/
Old Apr 6, 2004 | 03:51 PM
crnsuperduty's Avatar
Car: 88 sc. convert
Engine: 305 TBI
Transmission: Formerly 700-Now T5
I just cut mine out with a grinding wheel and welded a sheet of 14 ga. in place. I drilled drainage holes and mounting holes. After paint is looks pretty good.
Old Apr 6, 2004 | 07:51 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Justin
www.classicindustries.com or1800-854-1280.Part #s are R.H-G6844 & L.H-G6845.These are the genuine GM part.Price has gone up a bit though around $35-40
Old Apr 6, 2004 | 09:42 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
the battery tray also is part of the front fender support, so make sure what else is rusted out.
Derick15
Sep 17, 2016 05:28 PM
justin57
Aug 20, 2015 07:05 PM
Rakim_RS25TH
Car Audio
Aug 20, 2015 06:22 PM
Rakim_RS25TH
Aug 18, 2015 09:32 PM
