85-86 third brake light removal
Old Apr 10, 2004 | 10:18 PM
IROCZBeast's Avatar
Car: Looking For IROC
i'm looking around for a 305 manual iroc and i was really only looking from 87 and up because i really dislike the third brake light on top on the 85 and 86. i was wondering if i were to get an 85 or an 86 and wanted to remove the third brake light would that be a big hassle? would i have to remove it and replace the whole glass? is it worht it? is it even possible to do this removal? any info would help thanx
,nick
Old Apr 10, 2004 | 10:27 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
No third brake light on the 85's. The 86's and any 87 that did not come with a rear spoiler or wing had them (this would rule out any IROC's).
Removing that assembly would leave two holes in the glass, so You'd need to either swap the glass from an 82-85 or 87-90(?), or find a way to plug those holes.
Old Apr 10, 2004 | 10:45 PM
IROCZBeast's Avatar
oh ok thanx for the help
Old Apr 13, 2004 | 05:40 PM
benoit454's Avatar
Car: 86 camaro
Engine: 2.8 multiport cross fire injection
Transmission: 5 speed
My 86 has a spoiler on it it's the sport coupe almost every 86 no matter what had that 3rd brakelight on it.
Mine didn't work I took it off 2 torx heads on the inside takes it all loose wasn't a pain at all. I got another hatch glass but I plugged the holes off.
If you change hatch it just be 4 13mm nuts I think holds it on and 2 torx heads or 2 other smal bolts that hold the struts on the car or on the hatch and then swap em out the whole deck lid and all.
Removing just the glass fomr the hatch lid makes more work and is a bit harder and more involved.
I took me 2 bolts and used a washer on top and bottom and caulked the washers big time then tightened em down just a lil bit maybe a 1/4 turn w/ the ratchet 1/4 turn tighther then hand. I hand tightened them as much as I could then 1/4 turn w/ ratchet. worked fine. Didn't look bad w/ the bolts showing either but i put on a rear window louver anyways.
Vintageracer
Jan 10, 2020 05:33 PM
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
3rdgenparts
Aug 8, 2015 07:09 PM
