please help me problems getting worse!
Old Apr 22, 2004 | 01:39 PM
chevyrumble83's Avatar
Car: 1983 Z28
Transmission: TH350
the two screws that hold the gfx on the fender poped out of the fender, can someone please tell me how i can get to these screws???
in the pic below only one screw was out if u look u can see its off the fender ) but now the other one came out so its worse, how the heck do i fix this?? if i push the gfx the screws go in holes in the fender then just come out so the holes are two big now for the screws. i need info on this ASAP before it get worse or causes any real damage.
should i just take off the rocker z28 badge and drill two new holes???? this way when i put on the badge back on it hides the screws??
what should i do????
Old Apr 22, 2004 | 01:40 PM
Car: 1983 Z28
Transmission: TH350
4 got the pic sry.
Old Apr 22, 2004 | 01:55 PM
3gc's Avatar
3gc
Car: Z28
If they are held on the same as the 85-90 style you could pop the badge off and put a bolt/washer in there (with a slotted head for a screw driver), then take the wheel off and remove the the first few screws on the fender liner to gain access to put a washer and nut on the other side. Also you might want to use some locktite on that.
Old Apr 22, 2004 | 03:09 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
For the 82-84 camaros with gfx, the screws are located behind the emblem. Take the emblem off then you will see the two holes for the screws. To take the emblem off just use a thin flathead screwdriver and SLOWLY pry it off.
Old Apr 22, 2004 | 08:05 PM
Car: 1983 Z28
Transmission: TH350
oh 4 real that make this fix alot more easy..thanks for tell me.
would this be a good idea....take out the 2 old screws and put to new ones that are a bit thicker then the ones used so it will fit in the holes in the fender perfect???
Old Apr 22, 2004 | 09:41 PM
ES87iroc's Avatar
Car: 1987 Camaro Z28 IROC-Z
Engine: 5.7L TPI
Axle/Gears: 3.42:1
The factory screws are self-tapping. You will need the same if you go bigger, which is probably not a bad idea as they fell out of the fender. It can be tough to find a log self tapping screw though.
Old Apr 22, 2004 | 11:49 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
no problem bro my 83 ones were easy to take off. but installing the 91-92 ones were a pain in the butt!
83 Crossfire TA
Jan 3, 2016 01:26 PM
middian
Sep 5, 2015 01:42 AM
andy74
Sep 3, 2015 08:41 AM
Jackrabbit501
Sep 2, 2015 09:14 PM
greenyone
Sep 2, 2015 03:39 PM
