4th gen seats in 3rd gen?
Old Apr 29, 2004 | 10:41 PM
GearDrive63's Avatar
Car: 89 Camaro RS
I know its not a uncommon thing, but i never gave it any thought untill today. I just bought some and am picking them up on sunday. my question is this:
1.) are both the front and back both the same bolt pattern as the 3rd gen?
2.) Are they significantly more comfertable than the 3rd gen seats??
3.) all things considered; are they worth the hastle of buying and installing?
Old Apr 29, 2004 | 11:12 PM
7plagues's Avatar
Car: 92 Precision Red Firebird
Engine: v6->357 vortec xe262h rpm intake
Transmission: t5-> t56
Axle/Gears: 10bolt 3.42s
From what i hear its so simple its not even funny... but on the comfortable side i have no clue... i am kickin the idea around to do it myself. Where did u get urs?
Old Apr 29, 2004 | 11:15 PM
cg91ta's Avatar
Car: 1991 T/A - Sold (sniff) 1980 T/A Pa
I swapped my stock manual cloth seats for 4th gen power everything leather, and I do NOT regret it.
Bolt holes are identical on the seats and so they fit perfectly, including all of the seat belt hardware.
Old Apr 29, 2004 | 11:16 PM
aziroc's Avatar
Car: 86 IROC-Z
Engine: 406
1. yes
2. yes
3. its up to you.. but imo they r worth it.
Old Apr 30, 2004 | 08:37 AM
90RS305's Avatar
Car: 96 Silverado/99 Suburban
Engine: 700 cubic inches of 'Muican Awesome
Transmission: 4L80/4L60
Axle/Gears: Chunky/Clunky
I think you'll get a lot more in-depth info on this forum...
Old Apr 30, 2004 | 09:32 AM
Formula4Speed's Avatar
Car: 1990 Formula
Engine: 305 TBI (LO3)
Transmission: 5 speed manual
Bolt patterns are the same, mine are firmer than my 3rd gen seats and more supportive around turns and its not a hassle really. You can do it in half in hour if you have some basic tools, 13mm wrench and socket and a torx set for your ratchet and you'll be amazed how easy it is and how much nicer the interior looks with fresh seats.
Old Apr 30, 2004 | 11:54 AM
Deemax's Avatar
Car: '89 RS Convertible
Engine: 355
Much more comfortable, not much of a hassle, and everything bolts right in...unless you had the split rear seat backs, in which case you have to cut off the pivot that sits on top of the trans hump between the seats. But even that's easy enough to do...
Old Apr 30, 2004 | 03:38 PM
TFM4th's Avatar
Car: 87' Firebird
Engine: 2.8L
Transmission: Standard
Diddo, firmer deffinatly... mine are from a 4thgen Camaro and put them in my firebird
i didnt get leather, its cloth
30 minutes... it took me 15
looks awsome 2
Old Apr 30, 2004 | 04:18 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
I've been thinking about doing the same thing...my drivers seat is power...if I get a seat of 4th gen seats....how would I hook them so the power works? How did you do it? I'd LOVE to get a set of the Trans Am Graphite Leather Seats
Old May 16, 2004 | 09:51 AM
White91GTA's Avatar
Car: 1991 Trans AM GTA
Engine: 5.7L TPI
I just got a set of 4th Gen Leather seats yesterday. The driver seat is power and is causing me a few problems. The old driver seat that i pulled out was a manual seat and not power. My question is, how do i go about hooking the seat up so that the power works and how do i hook up the lumbar support and the other power accessory on the seat...i'm not sure what it is called?
Old May 16, 2004 | 11:48 AM
NEEDforSPEED's Avatar
:hail: 4thgen seats....
ya st8 bolt in.... a 3 year old could do it ....
the 4thgens are more frem then the 3rdgens....
i dont regreat swaping them.....
Old May 17, 2004 | 02:50 PM
BurninRed89's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
i went to the junkyard this past weekend and w/ my bro and friend and me and my bro both found two front seats from 4th gens, we came home, cleaned them up and put them roight in, took all of 30 min, not hard at all, and they are deff better, i dont slide around at all when i take corners fast and they are much more ocmfortable, the only hassle was trying to fit the 4 front seats, me, my bro and my friend in my camaro on the way home from the junkyard, lol
Old May 17, 2004 | 02:53 PM
Car: 1989 Camaro RS
Engine: 305 TBI
heres a pic of my new seats
Attached Thumbnails 4th gen seats in 3rd gen?-drivers-side-interior-new1.jpg
Old May 17, 2004 | 05:26 PM
Diabolical's Avatar
Car: 85 Trans Am WS6
Engine: 305HO L69
unless you're a complete stock **** or you don't have a $1 to your name, there's no reason why anyone shouldn't swap in 4th gen seats. they are far more comfortable, supportive, they look better, they are pretty cheap and easy to find, and they take as long as it takes to remove 10 nuts and 2 bolts, swap seats, and replace those 10 nuts and 2 bolts. if you have split back seats, you can still leave that center pivot bar and not really even notice it.
Old May 18, 2004 | 04:39 PM
mike88form350's Avatar
Car: 88' Formula 350
Engine: 358 ci TPI
Transmission: Tremec T-56
4th gen seats to 3rd gen so easy my dog could do it. if you have a split rear seat just remove the pivot and every thing fits perfect. no modification at all. for a power seat all the motor needs is power from the fuse pannel and a ground it does the rest. holy **** you even have access to a perfect ground!...the seat bolts!
Old May 18, 2004 | 09:10 PM
Z28GEN3's Avatar
Engine: 305TBI
Axle/Gears: B&W 9 Bolt 3.73
I plan on making seat swap before i ever drive the car, as they go back a few more inches then my stock seats Now just to find some red cloth seats, red leather just looks tacky, dont even know if it was ever made
Old May 21, 2004 | 12:14 AM
grngryoutmyway's Avatar
Car: 92 Z28
Axle/Gears: 3.73 10 bolt
As far as I know 4th gen seats only came in black, tan, grey, and white on some special edition cars.. you probably have to get them custom upolstered if you want red
And 4th gen seats are alot more comfy, I didnt like the power track cause it sits to high.. it adds a good 3 inches or so to the bottom of the seat so I just used the 3rd gen non power tracks
Old May 21, 2004 | 03:17 AM
Charlie's87's Avatar
Car: '87 t-top, '88 'vert
Red (and black) 4th gen seats:
http://cgi.ebay.com/ebaymotors/ws/eB...479598969&rd=1
Old May 21, 2004 | 12:01 PM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
I cut the adapter off my old seats and just added it to the new seats and plugged it in. Voila... easy.
Old May 26, 2004 | 10:42 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Axle/Gears: G80 3.23
Changing out the seats is so easy that I've already done it when I really havnt yet.
Old May 26, 2004 | 10:51 PM
FLYNLOW92rs's Avatar
They are worth it and IMO the firebird ones look better.....
Old May 26, 2004 | 11:11 PM
Outlaw87's Avatar
Car: 2002 Camaro SS
Engine: LS1 350 V8
Transmission: Automatic 4 Speed
Yeah 4th gen seats look great in 3rd gens and it sounds like they are easy to install... and from what ive heard they are much more supportive and comfortable.
Old May 27, 2004 | 06:04 PM
89V6FBIRD's Avatar
Car: 1999 Pontiac Trans Am
Engine: LS1 - 346 ci
They feel good on my butt...
Old May 27, 2004 | 06:05 PM
White91GTA's Avatar
Engine: 5.7L TPI
you ain't the only one...ride is way better with the 4th gen seats than it ever was with the stock seats
Old May 27, 2004 | 06:17 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Yall have never felt comfort until you sit in the old 80s model Mercedes seats. Full of springs.
Old May 28, 2004 | 10:33 AM
mike graycar's Avatar
Car: 88 iroc x 2- 1 T-Top, 1 Vert
Engine: 350 tpi, 305 tpi
Transmission: 700R4-2800 stall, 700R4 stock
got mine yesterday, Thanks 86irocnj, On the rears, they have no studs on the bottom to bolt to the body of the car. Am I missing something?
Old May 28, 2004 | 03:19 PM
shapeshifter's Avatar
Car: 1984 camaro
Engine: 60*V6
Transmission: 5spd
im thinking about going to the local yard and snagging some. about how much have you all paid for yours?
Old May 28, 2004 | 03:24 PM
You should be able to take the old hardware off your current seat back and put on the new one, just takes a T30 driver to pull out the screws.
Old May 28, 2004 | 03:35 PM
Mint black leather seats sell for about 750-900 dollars on ebay, cloth around 400-500. If you can find em in a wrecking yard you can probably expect to pay a couple hundred less...... unless the yard in your area sells on ebay If you can do some upholstery repair you can get a useable set for a lot cheaper.
Old May 28, 2004 | 06:40 PM
White91GTA's Avatar
Engine: 5.7L TPI
i got mint tan leather seats out of a 99 T/A from a guy in my club and paid 400 for the set.
Old Jun 6, 2004 | 04:06 PM
DoBeR's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Transmission: 4 Spd Auto
Im looking at buying a set of 4th gen seats but they dont include the seat tracks. Will they bolt right upto my 3rd gen seat tracks or no?
Old Jun 12, 2004 | 10:56 AM
White91GTA's Avatar
Engine: 5.7L TPI
yes....they are a direct bolt in so everything works.
Old Apr 6, 2006 | 07:54 PM
Oddball's Avatar
Car: '86 IROC-Z
Engine: LG4 305-4BBL
I'm buying a set of cloth non-power 4thgen T/A seats for $150.
Old Apr 7, 2006 | 01:48 AM
Dark Mavis's Avatar
Car: 94 Camaro Z28
Engine: 5.7L
Axle/Gears: GU5 3.23
Holy dead thread, Batman!
Old Apr 7, 2006 | 05:57 AM
Oddball's Avatar
Car: '86 IROC-Z
Holy I need to post to avoid the "you haven't posted in a few weeks" message from the new boardhosts :-)
And I'm doing the seat swap and wanted to make sure it would fit into my split seat.
Old Apr 7, 2006 | 02:13 PM
LUVmy92's Avatar
Car: Camaro
I love mine.
Old Apr 7, 2006 | 03:56 PM
Slepewesel's Avatar
Car: 91 Camaro Z28
Engine: 5.0 TPI (LB9)
Transmission: 4L60
1. Yes
2. Yes
3. Yes
91 Z with seats from a 96 bird, newly recovered with ebony leahter covers from a 00 Trans Am ...
Old Apr 8, 2006 | 01:01 AM
xlwhellraiser's Avatar
Car: 1992 Trans/am convertible
Axle/Gears: 2.73 drum WS6
I got my fourth gen camaro SS charcoal leather power seats for 50 (both). You just have to be patient, and they will show up at the yard.
To hook up your power seat all you need to do is hook the orange wire to power, and ground the black wire that comes from the seats harness. You can use the power from the light in the center console storage compartment. Just T into the power wire. It takes about 10 mins. to do.
All in all fourth gen seats are nicer, although a bit more firm than the stock ones. You'll like them!
Laters.
Frozer!!!
Jan 19, 2024 04:55 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Warlocksirix
Sep 3, 2015 12:26 PM
cam-mike
Aug 24, 2015 07:23 AM
