4th Gen T top holder
Old Apr 7, 2006 | 11:26 AM
jdk1987's Avatar
Car: 1992 Firebird
Engine: 3.1 V6
Would the third gen tops fit in this holder? Or are our tops too long? I have access to one and thought of getting it. It's just two peices at the bottom of the well, but I'm pretty sure 4th gen tops are bigger than 3rd...thanks.
Old Apr 7, 2006 | 11:41 AM
Jekyll & Hyde's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
I'm pretty sure that the curvatures of our tops are different from the 4th gens.
Old Apr 7, 2006 | 12:46 PM
Bluejae's Avatar
Car: 1988 Formula 350
Engine: L98 350 TPI
Transmission: 700-R4
I imagine with some time I could make a holder out of aluminum on the Bridgeport milling machine in my shop. I could probably do it all out of a solid chunk and just do it for both sides instead of plastic like the 4th gens.
Old Apr 7, 2006 | 12:53 PM
82 Pace z28's Avatar
Car: 82 Z28 Pace Car Edition restoration
Engine: 5.7l
Transmission: t56
Axle/Gears: 3.23 open drum (not 4 long)
Yo bluejae how much would you sell that for????
Old Apr 7, 2006 | 01:03 PM
bac67's Avatar
Car: 91 Camaro
Engine: LO3 305 TBI
Transmission: 5 Speed
I have a pair of 4th gen T-top holders if someone wants to buy them. I dont have t-tops so i cant test to see if they work
Old Apr 7, 2006 | 01:21 PM
Bluejae's Avatar
Engine: L98 350 TPI
typically going shop rate is $45 to $50 an hour, plus the cost of materials. I really don't know what exactly I would charge for it, but since I don't have 3rd gen t-tops on the formula I don't have anything to run a baseline test on.
Old Apr 7, 2006 | 03:03 PM
You would also have to figure out a way to mount the holder.
Old Apr 8, 2006 | 12:39 AM
Bluejae's Avatar
Engine: L98 350 TPI
Well I would be interested in doing it I can use the trunk on the formula for test mounting, I just don't have t-tops to find the correct curve and angle to make the slots.
Old Apr 8, 2006 | 06:14 AM
camaro430sut's Avatar
Car: 89 Camaro/ 02 GC Overland
Engine: 355 V8/ 4.7 HO V8
Transmission: T5/ 545RE
Axle/Gears: 10 Bolt 3.73/ Dana 30, Dana 44 3.73
the 4th gen ones dont work. i had a set and i had to mod the hell ot of em to get it close to fitting. it would be easier to just make something instead of tring to mod 4th gen ones. our t tops are much much bigger than 4th gens and the curvature is way different.
matt
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
cam-mike
Aug 24, 2015 07:23 AM
