Yet another hatch pull down unit question
Old May 3, 2004 | 09:24 PM
Swiftraptor's Avatar
Car: 1992 Chevy Camaro RS
Engine: 305 TBI
Yes, I did use search My question is a simple one: My friend shoved down on the rear hatch as the motor was lowering the trunk and I'm pretty sure the gear nut thing stripped out (motor running but no movement). So, is it a fairly simple process to disassemble the motor to replace the gear nut on '92s? Just want to make sure I'm not getting myself in over my head before i pull the assembly out. Thanks for the help.
Old May 3, 2004 | 10:09 PM
jay92,85,79's Avatar
Car: 85z28,
i did one once was not that bad . I went to a junk yard and did one there first just to make sure i could do it.
Old May 3, 2004 | 11:24 PM
Engine: 305 TBI
Hmm...that's actually a pretty good idea.
Old May 4, 2004 | 12:42 AM
TexasLT1's Avatar
Car: '92 RS
Its not that hard at all. You can get the nut for like $4 at the dealership. I just replaced mine.
Old May 4, 2004 | 02:03 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
The gear isn't stripped (it will strip though if you let it continually run), the motor housing broke. Mine did that 2 days ago so I gutted the motor and wiring and welded the rails together and now it's a manual hatch.
Ghettobird52
Jul 5, 2024 11:18 PM
Vintageracer
Jan 10, 2020 05:33 PM
AmorgetRS
Convertibles
Aug 31, 2015 11:55 AM
madsv1000
Aug 20, 2015 06:45 AM
redmaroz
Aug 16, 2015 11:40 PM
