How to take paint off?
Old May 9, 2004 | 02:49 PM
TBS84Camaro's Avatar
Car: 1984 Camaro Berlinetta
Engine: SB 350
Transmission: TH350
How do you get the old paint off the front bumper cover. I have a 87 Z28 bumper cover in my backyard that I got from a junkyard but the paint is all cracked and I have tried sanding it but didnt make a dent in it. I was just wondering if any of you knew of something to put on it that will strip the paint off. Thanks
Old May 9, 2004 | 03:17 PM
123jon321's Avatar
Car: '86 iroc
Engine: lb9 305
What grit sandpaper did you use? Don't use any higher than 180, that will take forever to make a dent. I used between 80 and 180 for my entire car and did it by hand, wasn't fun, but now I know better, I have now have a d/a sander
Old May 9, 2004 | 03:43 PM
JestahX's Avatar
Car: '85 Z28 Camaro
I've used 220 blocked and by hand on my whole car and i've spent a total of maybe 4 hours to sand half the car, that includes taking bumpers, GFX, door panels, moldings off the car.
I think 80 grit would put some mean marks that will have to be wet sanded out of the primer or it will show up when you paint? I wouldn't go any lower than 120 grit, Specially on polyurethane. To each his own though.
Old May 9, 2004 | 03:47 PM
Morley's Avatar
180 grit on a D/A sander. Walmart sells a nice Skill electric D/A for about $35
Old May 9, 2004 | 03:48 PM
123jon321's Avatar
Car: '86 iroc
Engine: lb9 305
Yeeaahh, come to think of it I think I only used 180 on my paint. I used 80 on my rims to get the clear coat off for polishing, but that was a little too low, sorry for the misinfo.
Old May 9, 2004 | 04:06 PM
TA's Avatar
TA
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
Check Autozone, they sell a spray on paint stripper for flexible bumpers. It doesn't work as well as the conventional paint stripper, but it does work eventually.
I would then use 120 grit for the first pass to clean up anything the paint stripper didn't get.
Troy
So Cal
Old May 9, 2004 | 04:40 PM
3gc's Avatar
3gc
Car: Z28
I tried 80 gritt on a DA on my front bumper and put a nice gash in it, oops lol. I then decided to play it safe and did the rest by hand. I had to use a flexible bumper repair kit to fix that screw up.
Old May 9, 2004 | 05:51 PM
Engine: SB 350
Transmission: TH350
Thanks guys I will have to wait until I get some more time off work and get the windows and such preped on my Camaro and then I will try that. I think I'm using like 200 grit paper but I'm goin to buy more tonite.
Hotrodboba400
Dec 10, 2019 07:07 PM
Drone358
Sep 21, 2015 08:54 PM
TheExaminer
Sep 6, 2015 11:40 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
