Harwood cowl seal
Old May 14, 2004 | 10:52 PM
25THRSS's Avatar
Harwood cowl seal
What are you guys doing about the rear cowl seal if you install a glass hood? Did you just drill holes in the hood and put the stock one back on or what?
Old May 14, 2004 | 11:16 PM
MTPFI-MAF's Avatar
Car: 1982 CAMARO;
Engine: 1985 LB9;
Transmission: T-5/
Leave the rear cowl seal off it lets some of the engine compartment heat a place to escape.
Old May 14, 2004 | 11:23 PM
25THRSS's Avatar
That's what the cowl hood is for. I want to keep the seal.
Old May 15, 2004 | 12:01 AM
MTPFI-MAF's Avatar
Car: 1982 CAMARO;
Engine: 1985 LB9;
Transmission: T-5/
The Cowl Hood is for the air to come around and in to the Open air filter to get more air in. It will also let more air out as in heat. I would and have left the seal off as you will find many members have.
Just my .02
Old May 15, 2004 | 12:03 AM
25THRSS's Avatar
The seal is staying. So what have others done to put it back on? I'm thinking just drill new holes.
Old May 15, 2004 | 08:21 AM
MTPFI-MAF's Avatar
Car: 1982 CAMARO;
Engine: 1985 LB9;
Transmission: T-5/
ok ok Go get some super strength Emblem Glue or Something to that effect, and put it on, I wouldn't drill holes because sometimes like on the cowl hood I had I installed Zuse fastners and it alawys got little Stress Crack leading form the hole.
Just my .02
Old May 15, 2004 | 12:39 PM
NEEDforSPEED's Avatar
leave it off, seals suck... why do you want one?
blah... iv drive in heavy pouring rain and no water got under the hood...
Old May 16, 2004 | 04:45 AM
stiers's Avatar
I would mount it to the cowl of the car before I put it on the hood.
Old May 16, 2004 | 06:28 AM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
If it`s a bolt on hood you can drill the holes...the seal has push on clips like a door panel
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
1Aauto
Sponsored Vendors
Oct 13, 2015 03:06 PM
